RP64 NAS Case, 1 month in
Hi Folks,
I've been experimenting with my NAS case and various drive configurations - 2.5", 3.5", SSD, Hybrid, Combinations - and I've settled on the use of 2 Seagate 12TB Exos drives (https://www.amazon.com/Seagate-256MB-Cache-Enterprise-ST12000NM0007/dp/B0759Q9FXZ/) (and they've released 14TB).  The lower capacity of the 2.5" SSDs didn't balance the lower capacity available.  By striping the two 12TB drives, I have almost 23TB of usable space and over 250MB/sec sustained write performance.
By using a low-profile, 5VDC fan (https://www.amazon.com/Wathai-80mm-10mm-Brushless-Cooling/dp/B07PXSB9W3/) and the standard low-profile RP64 heatsing and fan, I can maintain sub-40C temperatures when running all 6 cores with an artificial sysbench load.  During normal operation I usually see temps in the sub-30C range.
One step that I did take was to tape the SATA cables to keep them clear of the fan blades.
All together, a very good solution for a micro-NAS or media center/server.
Sounds like a really nice NAS build. Impressive.
  RP64 Won't Boot After Power Down ColPanic_ 10 19,477 06-27-2023, 07:31 AM
Last Post: dkebler
  NAS case HDD power cable failure (buck failure) ashleymills 1 4,487 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 2,935 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 4,754 12-04-2021, 05:14 AM
Last Post: Goffi
  RP64 TV box case with wifi Wizzard 2 6,357 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 8,824 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 3,406 01-09-2021, 05:24 PM
Last Post: kuleszdl
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 21,840 01-05-2021, 05:05 PM
Last Post: kuleszdl
  Release CAD files for NAS case or parts of it? diizzy 5 10,571 08-13-2020, 04:50 AM
Last Post: diizzy
  Best location for adhesive wifi antennas with NAS case callegar 1 5,321 02-17-2020, 12:40 PM
