RockPro64 boot problem
I'm using a Rockpro64 board with ArmBian distribution.
The board is connected via HDMI to a display and via USB to the touch screen controller.
When the USB of the touch screen controller is connected the RockPro64 does not boot: it stuck in the boot room, on the console the only message I get is:
DDR Version 1.22 20190506
In
then it stuck waiting for something.
If instead I remove the usb connection vs the touch controller, the RockPro64 boot normally.
Any ideas about the root cause of this problem? ANy solution?
Thanks in advance
BS
Max
I own two "rockpro64" boards.
And, I confirmed that one of them shows similar symptoms.
The problem occurs on a board with 4GB of RAM, no problem with 2GB of RAM.
Is this problem simply due to individual differences ?
Or is it due to differences in board RAM options ?
It can not be judged because the number of samples is small.
Is your "rockpro64" board 2GB? Is it 4GB ?
And what string is printed on the silk mark on the board ?
(06-20-2019, 04:33 PM)t4_4t Wrote: I own two "rockpro64" boards.
I'm using 2GB board. I'm not inthe office right now, so I can't telle you the string on the silk mark...
Max
  Installing Wifi drive for the RockPro64 John45595 0 331 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 9,616 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 120,752 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 786 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 683 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 697 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,316 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,407 05-18-2023, 10:46 AM
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 913 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,351 04-06-2023, 02:46 PM
