REMOVE ROCK64 BOOT LOGO
is there a way to remove the ROCK64 boot logo ?
I could change the android logo with a bootanimation.zip, but it still remain ROCK64 logo.
Any help will be appreciated.
Aurel
(03-15-2019, 12:44 PM)aurel Wrote: Hello,
Aurel
You have to replace the .bmp files in the root of the kernel directory and rebuild the kernel and install it
however you do it you will first need root. and you also need to grant write priviledge to the system directory. then you can just rename the current bootanimation. then just name the new file to bootanimation.zip. at least that's the way i did it from android 13 to 15. might have changed. also, i've never done it on these pine64 builds so maybe shripal17 is right about having to do what he says.
  rock64-android10-tv patchset for Firely AlexS 1 605 09-08-2026, 10:49 PM
  Android Images (ROCK64) pineadmin 77 245,190 11-18-2024, 08:21 AM
Last Post: reukiodo
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,628 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,507 03-12-2021, 01:38 PM
Last Post: Wizzard
  Android on Rock64 SD Problem ElBoluTony 3 11,329 10-07-2020, 12:10 PM
Last Post: ElBoluTony
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,969 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 16,283 09-09-2020, 08:44 AM
Last Post: BowerR64
  Boot Android from USB? Max_H 3 11,068 09-09-2020, 08:26 AM
Last Post: BowerR64
Question Regular Android build for Rock64? fender90 18 43,789 09-09-2020, 08:04 AM
Last Post: BowerR64
  Minimum requirements for ROCK64 Android install? eugenev13 0 6,288 06-04-2020, 02:23 AM
Last Post: eugenev13
