Boot Android from USB?
Hi
Is there a Rock64 Android which boots from USB? Preferably from Rock64's USB 3 socket?
This is what I have tried:
  • Bionic works flawlessly with a M.2 SSD in an USB 3 adaptor using the USB 3 socket.
  • With Etcher (Linux and Win10) and rock64_20171204_stock_android_7.1.2_rooted_emmc.img as well as rock64_20180606_stock_android_8.1_emmcboot.img Etcher reports "It looks like this is not a bootable image", this probably because of a missing partition table.
  • With Pine64Installer (v 2.0.0 beta 3, Win10) and Stock android 8.1 emmc (build 20180606) from the list I get  "Invalid Message Unhandled rejection undefined Invalid message" after download.
  • Flashing ayufan's android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img with Pin64Installer worked, but the image didn't boot.
Any suggestions?
Max_H
(10-11-2018, 08:56 AM)Max_H Wrote: Hi
Any suggestions?
Max_H
Sock Android may not possible to boot form USB. ayufan version may be and pending on ayufan update his build.
Any suggestions?
Max_H
Thanks for your reply. I will use an emmc to begin with and hope for an update.
Ive never thought to try to boot from the usb, will it even do that with out some kind of modification
  Android Images (ROCK64) pineadmin 77 245,828 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,406 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,691 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,857 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,855 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,560 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,731 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,384 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,663 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,023 09-18-2020, 07:58 PM
Last Post: BowerR64
