Android ( Stock or TV version ) rooted image please !!!
Wink
Hello everyone and good morning from Spain.
 I recently bought the Rock64 board and I would like to install the most recent and updated version of Android (Stock or TV) BUT it includes "root". That once installed, it is already with the "root" applied.
I want to install some applications BUT it is essential that the Android version is "root".
What is the LAST or most RECENT version of Android (Tv or Stock) that includes "root" and that is available for eMMC 16Gb?
Thank you very much and much encouragement, strength and courage Smile Smile
Looks like none of the current Android imgs come with root ootb, but you should be able to install Android and manually install root.
(06-17-2020, 06:07 AM)tophneal Wrote: Looks like none of the current Android imgs come with root ootb, but you should be able to install Android and manually install root.
Thank you.  Any tutorial or beginner's guide on how to root my device (Rock64) with the latest version of Android Stock or the latest version of Android TV?  Please, as easy as possible.  Thanks again.
(06-17-2020, 08:42 AM)AngelfromSpain Wrote: Thank you.  Any tutorial or beginner's guide on how to root my device (Rock64) with the latest version of Android Stock or the latest version of Android TV?  Please, as easy as possible.  Thanks again.
terribly sorry! I misread your OP, and thought you had a RockPro. With a Rock64, you have several options: https://wiki.pine64.org/index.php/ROCK64...e_Releases
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,253 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,018 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,544 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,335 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,015 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,497 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,005 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,574 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,722 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,772 09-09-2020, 08:44 AM
Last Post: BowerR64
