Regular Android build for Rock64?
Question
Dear Pine64 team! Why don't you make a regular Android build for Rock64? The TV UI in the stock OS is almost unusable with touchscreens. No navbar and status bar so it is very inconvenient to connect to network or adjust the volume. I just don't get it. Are there any TECHNICAL limitations for rk3328 for making a regular android os? Rock64 is a really great product and has a great hardware but the software side is a lot of pain
(08-18-2018, 06:53 AM)fender90 Wrote: Dear Pine64 team! Why don't you make a regular Android build for Rock64? The TV UI in the stock OS is almost unusable with touchscreens. No navbar and status bar so it is very inconvenient to connect to network or adjust the volume. I just don't get it. Are there any TECHNICAL limitations for rk3328 for making a regular android os? Rock64 is a really great product and has a great hardware but the software side is a lot of pain
There is no technical limitation. The ROCK64 using TV UI due to the primary video output is connected to TV.
So the question is if there are any plans to release a regular version of Android for this board?
(08-26-2018, 08:48 AM)fender90 Wrote: So the question is if there are any plans to release a regular version of Android for this board?
Probably not by the Rock team. I've been waiting patiently for this since I got my Rock64. It hasn't happened, so I doubt it'll happen now. The ROCKPro64 is supposed to be getting a stock version of Android, so perhaps you might want to update to that board? It also has the benefit of long-term support, something that the Rock64 doesn't have and as such will probably be dropped from development soon enough.
The current "Stock" version of Android for the ROCKPro64 does not have Play Services/Play Store yet though.
I'm debating getting one of these. For now, my Rock64 suits my needs just fine though.
I don't believe the Rock64 Development will be totally dropped as LibreELEC OS is being actively tested and developed with Rockchip employees participating. Android and Android TV Development is probably an unknown. Depending on your needs, the RockPro may be overkill when making a purchase decision. I've been using Ayufans' Android TV on my Rock64 eMMC and LibreELEC via SD Card Boot. Suits my needs.
I meant official development by the Rock64 team. I figure third-party development will stick around for a while after the team drops development.
I start to think that for my purpose of making a car entertainment system buying a Rock64 was a huge mistake and a waste of money. Though it has a pretty good specs, it doesn't have any OS which would work well with touchscreen
I feel the exact same way. I spent over $150 on the R64 and a bunch of accessories ,for essentially nothing. it sits in a drawer and about once a month I pop in hoping for a miracle.
(09-02-2018, 05:16 PM)ktulu909 Wrote: I feel the exact same way. I spent over $150 on the R64 and a bunch of accessories ,for essentially nothing. it sits in a drawer and about once a month I pop in hoping for a miracle.
There is another board by Firefly roc-rk3328-cc which has the came RK3328 soc and a regular android build. Hope someone will try to port it to Rock64
(09-04-2018, 12:34 AM)fender909 Wrote: There is another board by Firefly roc-rk3328-cc which has the came RK3328 soc and a regular android build. Hope someone will try to port it to Rock64
I have both Rock64 and Firefly roc-rk3328-cc.
I don't like Android TV UI on Rock64,  Android regular UI Firefly roc-rk3328-cc looks good.  But no way to put SuperSU on Android for Firefly roc-rk3328-cc (it is rooted).  No Google Play Store on Firefly roc-rk3328-cc.  Applications used to start an service such as "Auto Start" or "Autostart and Stay!" cannot start the service at boot.
I feel so weird about  Android 7.1.2 on roc-rk3328-cc.   but it is still usable to get and install all apps from APKPure.com
USB3 can only be used with Thumb Drives , but not stable with hard drive for Android 7.1.2 on both Rock64 and Firefly roc-rk3328-cc
For Linux, USB3.0 are stable for both boards: Rock64 and Firefly roc-rk3328-cc.
  rock64-android10-tv patchset for Firely AlexS 1 672 09-08-2026, 10:49 PM
  Android Images (ROCK64) pineadmin 77 245,850 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,412 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,693 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,862 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,862 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,565 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,736 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,386 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,667 09-18-2020, 08:12 PM
Last Post: BowerR64
