power
hey guys.
i just want to add a turn (on/off) button to my pine.
and can i install a cooling fan to it ?
any help please
With your Pine, you should have gotten a small button loose in the bag for your Pine. You can put that on either the Power or Reset 4-pin holes on the board. (Shown on the right side of this picture: http://wiki.pine64.org/images/7/7d/Pine6...nector.png )
For a cooling fan, you can get one from eBay or Amazon, just get one that runs off of 5V. You can power the 5v fan through the GPIO pins 4 and 6. (Shown here: https://drive.google.com/file/d/0B0cEs0l...IzTlE/view )
If you don't want to mess with wires on the cooling fan, you can get USB fans, for example these: http://www.amazon.com/gp/product/B002NVC1DS , and just plug them into your USB port.
If I've helped you with something, please leave a rating for my responses.
(04-21-2016, 08:52 AM)pine.tree Wrote: With your Pine, you should have gotten a small button loose in the bag for your Pine. You can put that on either the Power or Reset 4-pin holes on the board. (Shown on the right side of this picture: http://wiki.pine64.org/images/7/7d/Pine6...nector.png )
thanx alot man.
thumbs up.
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,536 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 38,941 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,617 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,706 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 29,487 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 11,184 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 53,220 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,857 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 29,694 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 58,161 10-05-2016, 06:43 AM
Last Post: Ghost
