Odd HDMI issues
Hey there,
I've been trying to set up the rock64 with an HDMI LCD (this one) for a while now. HDMI output works fine with regular monitors - however, when I try to connect to the LCD oddities follow. When using Ubuntu Mate, the LCD briefly flashes on (to a black screen) and off. I was told this may be an issue with resolution size, so I tried to use another monitor to change it; however, connecting to the LCD seemed to have broken the HDMI output. I re-flashed the MicroSD with an LXDE distro which seemed to fix the issue, then decreased the resolution before connecting to the LCD, but the same results occurred with the only difference being that the LCD displayed a 'no signal' message rather than flashing on and off.
Any suggestions? Thanks in advance.
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,534 01-17-2023, 02:31 PM
Last Post: Flagtrax
  Latest Manjaro Update fails HDMI Flagtrax 0 572 01-06-2023, 10:47 AM
Last Post: Flagtrax
Question Constant RockPro64 PCIe SATA Issues Kwarter 0 1,272 01-22-2022, 05:16 PM
Last Post: Kwarter
Question Hardware issues with Rock64 grobbs 10 9,986 04-08-2021, 05:24 AM
Last Post: t4_4t
  HDMI noise on Rock64 ab1jx 1 2,882 06-19-2020, 04:54 PM
Last Post: ab1jx
  Rock64 v2 network issues alephnull 2 4,830 05-29-2020, 06:00 AM
Last Post: maccarry
  Heat issues admiral_andersen 5 5,581 11-04-2019, 11:52 AM
Last Post: Rocklobster
  HDMI 2.0a CEC compliancy issue? Willem53 1 2,509 04-13-2019, 08:02 AM
Last Post: Willem53
Photo HDMI resolution bueschi 0 2,146 01-06-2019, 02:34 PM
Last Post: bueschi
  Performance and stability issues Openmediavault jgpacc 10 13,273 11-02-2018, 01:46 PM
Last Post: jgpacc
