Constant RockPro64 PCIe SATA Issues
Question
Howdy all,
I got a RockPro64 (4GB model) a while back and intended to use it as a NAS/Plex server.
Some info:
Running: Armbian Buster (Linux 5.10.63-rockchip64)
With: OpenMediaVault 5.6.21-3
I have had constant on and off issues getting my 6TB Seagate Ironwolf HDD to work with the RP. At first, I thought it might be the SATA card, so I replaced the Pine64 one with this card: https://www.amazon.com/gp/product/B07QGRVGVM
That worked for a few months, but then randomly the disk stopped showing up in the OMV filesystems menu. The disk still shows up in lsblk (sda):
rockpro64:/:% lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sda           8:0    0  5.5T  0 disk
mtdblock0    31:0    0   16M  0 disk
mmcblk1     179:0    0 29.7G  0 disk
└─mmcblk1p1 179:1    0 29.4G  0 part /
But the partition is unable to be found.
The disk now makes strange clicking noises when it powers on (brand new HDD by the way), and the noises don't match other HDD failure sounds I've seen posted on YouTube and other places.
I thought it might be due to insufficient power, so I replaced the 12V/5A PSU with a 12V/7.5A PSU, since some people had mentioned that worked for them. The drive label says that it only needs 1A, so the original 5A supply should have been more than sufficient.
To summarize:
  • 6TB 3.5" HDD was working fine for months with the original Pine64 power supply and the SATA adapter listed above.
  • The drive stopped working and even though it shows up in lsblk, the partition is missing and the drive makes strange noises when powering on.
What I've Tried:
  • Replacing the SATA card
  • Replacing the power supply
  • Replacing the SATA cable
Any ideas? I have no idea why it would work just fine for months, but then all of a sudden stop. If I plug the drive into my main PC, it reads no problem.
Tongue RockPro64 Ethernet NOP After Debian 11 Install... MattDralle 1 2,150 10-30-2021, 06:10 AM
Last Post: Rocklobster
Question Hardware issues with Rock64 grobbs 10 10,009 04-08-2021, 05:24 AM
Last Post: t4_4t
  Rock64 v2 network issues alephnull 2 4,832 05-29-2020, 06:00 AM
Last Post: maccarry
  Heat issues admiral_andersen 5 5,587 11-04-2019, 11:52 AM
  Performance and stability issues Openmediavault jgpacc 10 13,296 11-02-2018, 01:46 PM
Last Post: jgpacc
  Odd HDMI issues jman005 0 1,798 10-26-2018, 09:15 PM
Last Post: jman005
  Constant high load freeloader 1 2,398 07-17-2018, 11:40 AM
Last Post: jbk
