strange behaviour on newer kernel
I noticed that after upgrade to:
linux-image-4.4.154-1122-rockchip-ayufan-g7859b9b904a9 linux-headers-4.4.154-1122-rockchip-ayufan-g7859b9b904a9 linux-firmware-image-4.4.154-1122-rockchip-ayufan-g7859b9b904a9
My Fan stop and start, almost by itself..
Does anyone is experiencing the same?
I am um the bionic image..
(10-05-2018, 10:44 PM)tuxd3v Wrote: Hello,
Something that occurs me..
It could be that this newer kernel, only activate Fan, when temps reach 57°C ..
Because the hwmon facility, has 3 or 4 options..
which include
Throtling, and Active Thermal
And so maybe it is a feature..??
cooling-levels = <0 80 170 230>;
lines: 279...286 and 645...669
(10-06-2018, 12:32 PM)romtorwator Wrote: cooling-levels = <0 80 170 230>;
thanks for that  Shy
the fan will need more power at start.
For example in fanctl I start it like:
130
200ms
190
1 second
so that it can gain momentum, then I set the pwm to a value, imagine 40.
The fan already started it can then be at 40..
I don't advise going lower than 30-35, it depends again..
because of it, I choose 40 as minimum..
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 867 09-22-2023, 04:27 AM
Last Post: diederik
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 1,160 06-16-2023, 10:54 AM
Last Post: CounterPillow
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 1,858 05-08-2022, 03:26 PM
Last Post: paralin1
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 1,472 04-04-2022, 05:29 PM
Last Post: ajtravis
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 2,320 09-11-2021, 08:58 PM
Last Post: t4_4t
  compiling a new kernel for overclocking on arch Mentaluproar 2 2,803 07-15-2021, 10:16 AM
Last Post: Mentaluproar
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 3,045 07-14-2021, 02:37 PM
Last Post: TRS-80
  ayufan kernel update unbootable TheHunter 2 3,209 03-12-2021, 05:17 PM
Last Post: LMM
  Kernel oops after big-ish writes gaeb 1 2,368 02-11-2021, 03:55 PM
Last Post: gaeb
  Please help me troubleshoot strange network performance UnoqueVa 1 2,462 11-01-2020, 03:05 PM
Last Post: guannais
