Netrunner 18.03 Idolon for the Pinebook
#41
After reinstall the sound started working, after sleep it stopped.
#42
This is awesome! I'm downloading the image now! Great work shadeslayer & co! Quick question though, did you ever get suspend/resume working correctly with drm enabled? (or at least working as well as the xenial mate images without it)
#43
Does anyone of you also have problems with wifi?
#44
Anyone alse tried that?
It would be a good OS if the sound and sleep mode worked correctly.
#45
(04-30-2018, 07:57 AM)amilino Wrote: Does anyone of you also have problems with wifi?
Hey
We've discovered that we do not set a static MAC address for the WiFi card, this will be fixed in the next image. For now you can workaround this issue by using issuing this command :
echo 'options 8723cs rtw_initmac=00:81:c1:55:17:0a' > /etc/modprobe.d/8723cs.conf
(05-05-2018, 08:01 AM)Wizzard Wrote: Anyone alse tried that?
Hey
Could you try out :
alsactl restore /var/lib/alsa/asound.state
After resuming from sleep to check if it fixes your sound issues?
(04-30-2018, 07:52 AM)ctrlaltbeast Wrote: This is awesome! I'm downloading the image now! Great work shadeslayer & co! Quick question though, did you ever get suspend/resume working correctly with drm enabled? (or at least working as well as the xenial mate images without it)
Hey
Yes, this should work.
#46
alsactl: load_state:1763: Cannot find soundcard '/var/lib/alsa/asound.state'...
#47
Ah oops, that should have been :
alsactl -f /var/lib/alsa/asound.state restore
#48
shared memfd open() failed: Function not implemented
#49
Try it as root please (with sudo) Smile
#50
(05-15-2018, 03:10 AM)leszek Wrote: Try it as root please (with sudo) Smile
I run it with sudo, of course. Without sudo, there were a lot of other errors.
  DietPi OS for Pinebook MichaIng 3 5,473 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,363 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 936 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 727 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,745 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,251 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,910 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,286 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,837 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,815 12-25-2020, 04:40 PM
Last Post: ford442
