Netrunner 18.03 Idolon for the Pinebook
Hi everyone!
I'm excited to share that we have a release of Netrunner out for the pinebook now!
You can read more about it here :
https://www.netrunner.com/netrunner-for-pinebook/
https://kshadeslayer.wordpress.com/2018/...-pinebook/
We'd love to hear your feedback over here in the comments section!
(04-17-2018, 10:02 AM)shadeslayer Wrote: Hi everyone!
Looks impressive. Downloading the torrent now and willl slap it onto my pinebook 11" tonight. Any chance for a release on the Rock64 as well?
Great job! Could you make a release for PineA64 2gb version too?  Angel
Good morning to all
I would like to say that I liked all the potentials of this OS, especially visually spectacular but it is in the testing phase and it shows.
1) The wifi management does not work well, you have to enter password every time and there comes a time that you never recognize it.
2) The version of the terminal closes when it is in the background and must be reopened.
3) When starting well every time it does not get to do well and you have to turn off to start again.
thank to pine forum.
Thanks a lot for the update shadeslayer Smile
(04-18-2018, 02:45 AM)vv1 Wrote: I would like to say that I liked all the potentials of this OS, especially visually spectacular but it is in the testing phase and it shows.
Thanks vv1, I'll try to answer some of the things:
1) yes, this is a known issue. I added it to the errata and it will be fixed with a future update, once it lands in Debian Testing.
2) if you mean yakuake, there is a small button on the right edge that looks like a "pin/needle" that you can press to have the terminal stay opened in the front.
3) can you check if something is running in the background right after login? it could be apt/xapian is refreshing its index or some other process temporarily makes things a bit slower, depending on the sdcard in use, as it is all performed on there. If nothing else runs, it should be very smooth and low-memory footprint (please note and deduct the FF+Web processes, that are automatically loaded in the back for a very quick start of FF, so if you close those processes, it should be around 350-400MB RAM in idle mode).
If you have any wishes or improvements like programs missing, please let us know and we consider them with the next update!
Quote:1) The wifi management does not work well, you have to enter password every time and there comes a time that you never recognize it.
Have you run the installer? Networkmanager has a bug that it asks a second time about the password in live mode. It doesn't do this when installed though.
Quote:2) The version of the terminal closes when it is in the background and must be reopened.
That is something you can configure in yakuake -> settings -> behavior.
By default we stick to that what we have on Netrunner 18.03 x86 aswell.
Quote:3) When starting well every time it does not get to do well and you have to turn off to start again.
Can you clarify on this?
Do you mean logout and login? Or restart?
1) conect to wifi is very dificult. Thanks for to answer.
2) thanks change to behavior.
3) restar , only two times post to install distro. No more time. Already now. Thanks
the mac theme is good for all, thanks for this distro.
Thanks pine forum
Looks great! but is it possible to install onto eMMC ?
Currently the installer only uses the microSD Card to expand the to the maximum that this card offers.
Manually dd'ing might be possible though it isn't officially supported (please don't try if you don't know how to recover)
  DietPi OS for Pinebook MichaIng 3 5,370 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,907 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 891 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 685 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,575 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,218 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,844 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,242 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,806 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,794 12-25-2020, 04:40 PM
Last Post: ford442
