setup root on stretch arm64 ayufan
Hi all,
I'm just testing a few linux builds on my new rock64.
The ayufan all have rock64/rock64 as default user but I want to login as root. How can I do this?
Many thanks
(12-07-2017, 12:11 PM)jata Wrote: Hi all,
Many thanks
I dont think a root password is set. So if you want to login / ssh in as root you will have to set a password for root.
Otherwise you cand just sudo su
Thanks. yes i do want ssh as root. So how do I set a password for root?
Like for any other user
sudo passwd root
First it will ask you to enter your password since you're using sudo. Then it will ask you to create a new password - that will be the password for root.
Thanks.
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 4,240 05-09-2020, 03:15 AM
Last Post: lawrencejd
  Ayufan LXDE with Teamviewer or Dwservice? cenicero 0 1,995 03-14-2020, 06:39 AM
Last Post: cenicero
  Arch-Manjaro attempting gles2 setup tomarm 2 3,446 12-28-2019, 01:33 AM
Last Post: tomarm
Information New Builds from ayufan (0.8.X) w Video/3D/Mate desktop Luke 37 53,206 09-09-2019, 04:01 AM
Last Post: ayufan
  Upgrading Debian Stretch image to Buster cosuhi 2 4,737 08-27-2019, 02:42 AM
Last Post: Malmgren
  Howto setup Q4OS on Rock64 q4osteam 1 4,288 08-17-2019, 02:07 AM
Last Post: DonnaAlfaro
Star [archived] New Stable release from Ayufan (0.8.3) Luke 3 6,911 07-10-2019, 10:40 AM
Last Post: Malmgren
Star ayufan's 0.8.0rc12 (Rock64 Rev 3) Luke 1 3,313 06-13-2019, 02:05 AM
Last Post: pineadmin
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 2,273 03-26-2019, 07:28 PM
Last Post: Poincare
  ayufan 0.7.12 pre-release images (help testing) Luke 1 4,589 03-22-2019, 05:11 PM
Last Post: Luke
