Howto setup Q4OS on Rock64
Directions for those, who would like to check Q4OS running on Rock64:
https://www.q4os.org/forum/viewtopic.php?id=2410
Q4OS on Rock64 is pretty snappy and runs fast. A feedback would be appreciated.
ROCK64 is a 4K60P HDR single board computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor 4GB RAM, see:
https://www.pine64.org/?page_id=7147
As Q4OS setup tool has been ajusted and tested for Rock64 boards, installation on Rock64 is pretty easy. You will need to install Armbian Stretch first https://www.armbian.com/rock64/ , and then run Q4OS setup script, just follow the Q4OS documentation:
https://docsbay.net/a-clean-install-of-q...arm-device
Q4OS on Rock64 hardware is pretty snappy and runs fast. Any feedback would be appreciated.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 151 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,361 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 609 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,383 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,449 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,360 12-07-2022, 08:22 PM
Last Post: luminosity7
