Upgrading Debian Stretch image to Buster
I installed a while ago ayufan's Debian Stretch image on a Rock64 as a server, and wanted to know if it was possible to upgrade it directly to Debian 10 Buster by following the standard upgrade procedure (i.e by changing the repo versions in /etc/apt/sources.list), or if there was some things to be taken care of first, like switching to another custom repo, switching kernels, etc.).
Thanks in advance !
Yeah thier is a sed hack that replaces the version as a script.
sed -i '$ a\\ndeb http://packages.dotdeb.org wheezy all\ndeb-src http://packages.dotdeb.org wheezy all' /etc/apt/sources.list
This was on stackexhange..
At any case buster instead of wheezy, and likewise your local arm64 mirrors...
Apt distro upgrade , (something like that)
similar sed trick will replace all
"Old-distro-codename" with buster.. using sed..
And also easily in /apt/sources file/s..
Also a apt sources generation site. ,
Adds many things ie dropbox Google's chrome etc.
may need to edit, as some are arm7hf or x86 or amd64,
Or sdeb.. if that can get sdeb and build locally..
I typically use Gentoo anyway, but as emmc build root ... debian been used as xdcard host.
Sent from my SM-N960U using Tapatalk
https://linuxize.com/post/how-to-upgrade...10-buster/
This has main article you might like and sed stretch to buster..
Did you check the upgrade instructions on https://github.com/ayufan-rock64/linux-build/releases? I guess they would be a good starting point, plus a change from stretch to buster in /etc/apt/sources.list.
  How to update/compile Debian 12.5? Wizardknight 3 400 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,280 10-12-2023, 05:14 PM
Last Post: tpaul
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 5,242 08-12-2021, 04:55 AM
Last Post: igorp
  Debian build from mrfixit2001 Luke 18 27,109 05-17-2021, 02:35 AM
Last Post: Wizzard
  NextCloudPi image for Rock64, NC version 13.0.2. nachoparker 11 23,323 03-15-2021, 02:59 PM
Last Post: kiriakos
  Debian kernel stuck at 4.4.167 Enig123 5 5,612 12-29-2020, 12:57 PM
Last Post: kwinz
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 5,246 09-21-2020, 04:33 AM
Last Post: as365n4
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 4,216 05-09-2020, 03:15 AM
Last Post: lawrencejd
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,147 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Underclocking the Rock64 (latest stable linux image) va88 2 4,285 08-07-2019, 05:39 PM
Last Post: evilbunny
