HDMI 1024 x 600
Exclamation
I have a HDMI display that is 1024x600 that I want to use on the pine64+ 2GB system running Debian 20160701. I tried Longsleep's tool sunxi-disp-tool but as far as I know it does not support it. Any ideas on how I can do this?
Thanks,
Mus1c
Its not a matter of sunxi-disp-tool as it can set all resolutions which are supported by the disp2 driver. For Pine64 this is a subset of - https://github.com/longsleep/sunxi-disp-...go#L13-L44 - look into the kernel driver source for the exact values. Other resolutions would need to be added to the kernel driver (some parts are closed source).
Okay, baby steps, I ran some commands starting with:
1. sunxi-disp-tool switch -name 1024x600
2. sunxi-disp-tool switch -mode 0x1f
3. sunxi-disp-tool switch -mode 0xffff
4. sunxi-disp-tool switch -mode 0xe
Does it need to be added? Am I doing this all wrong?
I'm sorry about my inexperience. All my knowledge on linux is based on trial and error or following the directions.
What longsleep wanted to say it that 1024x600 is not a resolution that is supported by the current HDMI driver.
I really hate being this newbie guy. Could it be possible in a future driver update? I just want to know if I need to return it to amazon or not. If it is time is irrelevant, just knowing it is a possibility assures me it will be a good investment.
Sad HDMI to DVI Color issues? leatherlips 5 15,183 10-09-2017, 05:57 AM
Last Post: Luke
  Would HDMI screen for Raspberry PI work? dhewko 1 3,443 07-23-2017, 06:43 AM
Last Post: MarkHaysHarris777
  HDMI-DVI aminhb 11 17,431 01-08-2017, 10:52 AM
Last Post: Luke
  HDMI issues rahlquist 35 45,279 12-24-2016, 02:20 AM
Last Post: sboyce
  Monitor no output (through HDMI to DVI adaptor) gam01hr 10 14,835 11-15-2016, 01:46 PM
Last Post: Armbian User
  HDMI CEC ayufan 15 19,519 09-08-2016, 10:24 AM
Last Post: ayufan
  HDMI to VGA adapter for Android PineA64 tech support setup MarkHaysHarris777 0 2,397 08-06-2016, 12:47 PM
  hdmi_group CEA or DMT hdmi group specify uEnv.txt MarkHaysHarris777 2 4,980 07-01-2016, 08:23 AM
  No CEC over HDMI? utdrmac 2 5,609 03-07-2016, 03:05 PM
Last Post: utdrmac
  HDMI 3D, ARC + Ethernet Channels? bigmacattack 4 11,988 01-29-2016, 06:29 PM
Last Post: StefanB
