12-12-2015, 12:32 PM
I see that HDMI CEC will be supported, but what about some of the other features of HDMI 1.4 such as 3D, the Audio Return Channel (ARC) and the Ethernet Channel?
HDMI 3D, ARC + Ethernet Channels?
12-13-2015, 03:22 AM
(12-12-2015, 12:32 PM)bigmacattack Wrote: I see that HDMI CEC will be supported, but what about some of the other features of HDMI 1.4 such as 3D, the Audio Return Channel (ARC) and the Ethernet Channel? The Audio Return Channel (ARC) and the Ethernet Channel are not supported. Not sure about 3D and needs to explore further.
12-18-2015, 01:26 AM
i see in the allwinner website
- Supports HDMI 3D function http://www.allwinnertech.com/en/clq/proc.../6053.html
12-19-2015, 12:19 AM
(12-18-2015, 01:26 AM)hazerty Wrote: i see in the allwinner website Noted, since I have not tested the 3D function and confirmed works well, I rather give an unsure answer first.
01-29-2016, 06:29 PM
(12-13-2015, 03:22 AM)tllim Wrote:(12-12-2015, 12:32 PM)bigmacattack Wrote: I see that HDMI CEC will be supported, but what about some of the other features of HDMI 1.4 such as 3D, the Audio Return Channel (ARC) and the Ethernet Channel? Note that ARC is not really useful for most HDMI sources. ARC is used by AV receivers in case the video output port is repurposed as an audio input port, for TVs if the input port is used as an audio output port. This would be only useful if you used the satellite/cable receiver inside your TV and output the audio from the Pine. |
HDMI to DVI Color issues? | leatherlips | 5 | 15,140 |
10-09-2017, 05:57 AM Last Post: Luke |
Would HDMI screen for Raspberry PI work? | dhewko | 1 | 3,431 |
07-23-2017, 06:43 AM Last Post: MarkHaysHarris777 |
HDMI 1024 x 600 | mus1c | 4 | 6,205 |
01-09-2017, 07:30 AM Last Post: mus1c |
HDMI-DVI | aminhb | 11 | 17,394 |
01-08-2017, 10:52 AM Last Post: Luke |
HDMI issues | rahlquist | 35 | 45,209 |
12-24-2016, 02:20 AM Last Post: sboyce |
Monitor no output (through HDMI to DVI adaptor) | gam01hr | 10 | 14,780 |
11-15-2016, 01:46 PM Last Post: Armbian User |
HDMI CEC | ayufan | 15 | 19,482 |
09-08-2016, 10:24 AM Last Post: ayufan |
HDMI to VGA adapter for Android PineA64 tech support setup | MarkHaysHarris777 | 0 | 2,392 |
08-06-2016, 12:47 PM Last Post: MarkHaysHarris777 |
hdmi_group CEA or DMT hdmi group specify uEnv.txt | MarkHaysHarris777 | 2 | 4,967 |
07-01-2016, 08:23 AM Last Post: MarkHaysHarris777 |
No CEC over HDMI? | utdrmac | 2 | 5,590 |
03-07-2016, 03:05 PM Last Post: utdrmac |
