Node.js is not installed properly on Pine64
I installed node.js on ubuntu image using nvm.
nvm is very cool and best way to install node.js.
I guess, something is missing in kernel provided by longsleep...
ubuntu@pine64:~$ file $(which node)
/home/ubuntu/.nvm/versions/node/v7.3.0/bin/node: ELF 64-bit LSB executable, ARM aarch64, version 1 (GNU/Linux), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, for GNU/Linux 3.7.0, BuildID[sha1]=3d0c1229bb16cd420c34649d3763ec5e2d1fe03b, not stripped
ubuntu@pine64:~$ ldd $(which node)
    linux-vdso.so.1 =>  (0x0000007fb0212000)
    libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000007fb01f9000)
    libstdc++.so.6 => /usr/lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000007fb006a000)
    libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000007faffbe000)
    libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000007faff9d000)
    libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000007faff71000)
    libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000007fafe2a000)
    /lib/ld-linux-aarch64.so.1 (0x000000557faf8000)
ubuntu@pine64:~$ sudo apt-cache search linux-vdso
ubuntu@pine64:~$ sudo apt-cache search aarch64
qemu-system-arm - QEMU full system emulation binaries (arm)
qemu-system-aarch64 - QEMU full system emulation binaries (aarch64)
I fail to see the problem.
  Disable HDMI Pine64 Andruxa89 1 4,239 01-31-2019, 11:18 AM
Last Post: martinayotte
  Unable to run hello-world docker container on Pine64 kamtschatka 2 5,483 01-24-2019, 04:29 AM
Last Post: arboehm
  KDE on pine64? jamiechang917 6 10,120 01-14-2019, 01:47 PM
Last Post: brigmohan
  External DAC - Pine64 mjgoode 2 5,115 09-05-2018, 12:12 AM
Last Post: mjgoode
  Summer Undergraduate Research using Pine64's pkivolowitz 3 5,133 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 2,920 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 3,878 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Finally got Emby server running on Pine64 clarkss12 3 6,303 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 4,993 09-04-2016, 09:25 PM
Last Post: S265
  pine64-debootstrap sgjava 0 2,200 08-19-2016, 06:09 PM
Last Post: sgjava
