Unable to run hello-world docker container on Pine64
Has anyone managed to run docker images on pine64?
I have managed to get docker running by following this guide: https://docs.docker.com/install/linux/docker-ce/ubuntu/
The problem is then that I get this message:
Quote:no matching manifest for unknown in the manifest list entries
Has anyone encountered this problem before?
I have also seen some mentions of a linux image for container(basically i want to run kubernetes on pine64, but i can't even get docker to run properly). From what I could see this is discontinued?
docker worked for 15s for me.
installed from dietpi-software
then
sudo docker run hello-world
(01-18-2019, 03:54 AM)j2l Wrote: docker worked for 15s for me.
then
Please try to run
docker run aarch64/hello-world
This works fine for me, but requires always to specify the architecture.
  Disable HDMI Pine64 Andruxa89 1 4,199 01-31-2019, 11:18 AM
Last Post: martinayotte
  KDE on pine64? jamiechang917 6 10,011 01-14-2019, 01:47 PM
Last Post: brigmohan
  External DAC - Pine64 mjgoode 2 5,088 09-05-2018, 12:12 AM
Last Post: mjgoode
  Summer Undergraduate Research using Pine64's pkivolowitz 3 5,086 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 2,901 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 3,857 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Node.js is not installed properly on Pine64 nsisodiya 1 3,526 12-29-2016, 12:48 AM
Last Post: longsleep
  Unable to start Pine Topgun505 16 17,849 11-13-2016, 12:01 AM
Last Post: Gnx
  Finally got Emby server running on Pine64 clarkss12 3 6,258 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 4,965 09-04-2016, 09:25 PM
Last Post: S265
