KDE on pine64?
Is it possible to run Kubuntu on the Pine64?I really want to use KDE desktop on my Pine64.
Try. You can install base image, then
sudo apt-get update
sudo apt-get install kubuntu-desktop
Hi, have you tried it?
I am waiting for my Pinebook and would like to try Kubuntu desktop too.
Installing now. Will post my endeavours, whether they're good or not.
Kubuntu wants bigger /boot and crashes dpkg when I try to install it. The Mate desktop running on the pinebook as default is snappy and complete, so I see no reason to install KDE as it will probably be pretty sluggish. The accounts-part of Telepathy breaks during install, and now I can't install packages. The Pinebook is getting android anyways, so I can't be assed to spend more time trying to mess with KDE.
I guess you could do a sneaky dist-upgrade to KUbuntu Desktop with 50 megs more space on /boot, but be prepared for quite a lot of hacking and slamming your face into brick walls. Smile
q4os image has elements of kde and i suppose you could install more . i think q4os is debian based.
(04-28-2017, 11:56 AM)CaptainZalo Wrote: Installing now. Will post my endeavours, whether they're good or not.
Do you think is it possible to resize the partitions easy way?
"filetype" resize "amount"
  Disable HDMI Pine64 Andruxa89 1 4,201 01-31-2019, 11:18 AM
Last Post: martinayotte
  Unable to run hello-world docker container on Pine64 kamtschatka 2 5,442 01-24-2019, 04:29 AM
Last Post: arboehm
  External DAC - Pine64 mjgoode 2 5,089 09-05-2018, 12:12 AM
Last Post: mjgoode
  Summer Undergraduate Research using Pine64's pkivolowitz 3 5,088 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 2,901 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 3,859 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Node.js is not installed properly on Pine64 nsisodiya 1 3,530 12-29-2016, 12:48 AM
Last Post: longsleep
  Finally got Emby server running on Pine64 clarkss12 3 6,261 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 4,968 09-04-2016, 09:25 PM
Last Post: S265
  pine64-debootstrap sgjava 0 2,184 08-19-2016, 06:09 PM
Last Post: sgjava
