Summer Undergraduate Research using Pine64's
Hi All,
I am leading two undergraduates on a summer research experience. My question follows this brief project description.
The goal of the project is educational not necessarily practical so after reading what comes next causes you to say to yourself: Why would you do that? The answer is to get down and dirty and learn.
We aim to modify Ubuntu to assert affinity only over certain cores and a portion of physical memory and during boot, load and launch a parallel real time OS. Certain hardware on the Pine64 will be stripped from Ubuntu and given over to the conjoined twin. Hardware related code such as interrupt handling will be modified to multiplex as needed. A thread safe intercommunications portal will exist allowing applications on Linux to exchange data with plugins running on the conjoined twin.
My first question is to confirm I'm downloading the right source code for this purpose (work starts in 3 weeks so I'm getting prepared).
Was this the right place? https://github.com/ayufan-rock64/linux-kernel.git
Thank you all
(05-13-2018, 09:20 PM)pkivolowitz Wrote: Was this the right place? https://github.com/ayufan-rock64/linux-kernel.git
Which board are you going to use?
The reason I ask is because that link is for rock64 boards, where as you have posted this in the Pine64 category.
Er, no. That is the git repo for the kernel for the rock64, not the pine64. You're close though! Wink
https://github.com/ayufan-pine64/linux-pine64 gives you the kernel for the pine64
https://github.com/ayufan-pine64/u-boot-pine64 gives you the uboot loader
https://github.com/ayufan-pine64/boot-tools has some boottools
https://github.com/ayufan-pine64/linux-build has all the build scripts and Jenkins automated build files
That should get you started, or thoroughly confused at least! Big Grin
GAK! You are very right - I purchased a Pine64 for myself months back but purchased Rock64's for the student's work this summer.
I'll try again (with apologies) in the Rock64 group.
Sorry!
  Disable HDMI Pine64 Andruxa89 1 4,223 01-31-2019, 11:18 AM
Last Post: martinayotte
  Unable to run hello-world docker container on Pine64 kamtschatka 2 5,462 01-24-2019, 04:29 AM
Last Post: arboehm
  KDE on pine64? jamiechang917 6 10,078 01-14-2019, 01:47 PM
Last Post: brigmohan
  External DAC - Pine64 mjgoode 2 5,103 09-05-2018, 12:12 AM
Last Post: mjgoode
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 2,912 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 3,872 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Node.js is not installed properly on Pine64 nsisodiya 1 3,544 12-29-2016, 12:48 AM
Last Post: longsleep
  Finally got Emby server running on Pine64 clarkss12 3 6,291 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 4,984 09-04-2016, 09:25 PM
Last Post: S265
  pine64-debootstrap sgjava 0 2,193 08-19-2016, 06:09 PM
Last Post: sgjava
