May dietpi save Pine64 ; watch youtube via chromium
More "standard way" to create swap files is :
$ dd if=/dev/zero of=/path/to/swapfile bs=1M count=512 # For 512MB swap file
$ mkswap /path/to/swapfile
$ swapon /path/to/swapfile
"free" command will shows both real memory and swap.
(03-09-2017, 02:52 PM)martinayotte Wrote: More "standard way" to create swap files is :
Thank you, martinayotte.  I suppose the DietPi devs had some sort of reason to go the other route.
In the course of trying to watch youtube videos, I notice that if I let them load while I put them on pause some (at least) will actually play normally (no stop-and-go/buffer catchup) eventually.  I'm still trying to figure out how the OP did it.
(03-09-2017, 07:20 AM)kenneth558 Wrote: Yes, I did but didn't think to include it because the swapon command produced no response.  My bad in not posting that info.  Thank you kindly for asking.  Did you enable swap via fstab instead?
I run 1GB/2GB boards headless, so haven't run into any memory issues as yet, so I haven't needed to enable swap space on the pine64 (yet!) Wink
martinayotte has since posted the way I would normally create and enable swap files. When working with swap partitions, you still use the mkswap command to prepare the swap space and swapon to enable it. And you can add either the file or partition version of swap space to the /etc/fstab line in order to make it persistent across reboots.
You would add (using the correct path instad of /dev/hdb1) the following to /etc/fstab for a swap partition...
/dev/hdb1       none    swap    sw      0       0
... or the below (again, replacing /swapfile with the path to the swapfile) for a swapfile.
/swapfile       none    swap    sw      0       0
This article may help if anyone wants to learn more about the reasons for and how to make swap files/partitions.
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 2,432 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 4,666 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to get Netflix to work in Chromium or Firefox on PBP User 17828 13 24,362 09-24-2020, 08:52 AM
Last Post: solostian
  Just discovered Pine64 ! - first Q philip_rhoades 4 7,502 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 4,944 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 178,631 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 10,855 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 18,998 03-28-2019, 11:43 PM
Last Post: InsideJob
  Dietpi marekf 1 3,746 03-22-2019, 01:49 PM
Last Post: Violette
Information Creating a NAS server in Pine64 javi_cala 4 9,941 01-21-2019, 02:03 AM
Last Post: bartes
