Emails from pine64 received as spam by gmail
Hi everyone,
I have recently registered an account to join the forums and I received no confirmation email at first, I later found it in the spam folder of my gmail account.
The header says:
Quote:Why is this message in spam? It is in violation of Google's recommended email sender guidelines.
Not sure if this is the place to note this and I couldn't find a reference for it when searching through the forums.
I clicked the 'Report Not Spam' button, but I figured you might want to take care of it on your side as well.
We're aware of the issue. There are plans for how to fix it, but we're not going to implement them until the current phase of Pinebook Pro preorders is over.
Likely the same issue but, the confirmation email is completely rejected by mailbox.org by default.
By default mailbox.org completely rejects email it considers spam. I thought I had it setup to put spam in the "Junk" folder but the settings are a bit tricky if you don't pay close attention to the FAQ here. If a "technical filter" (Greylisting, SMTP Plausibility check, Realtime Blacklist) is enabled, emails that match the technical filter will be *rejected* and not put in Junk, as the "move to Junk" option is only for the content filter. The confirmation email matches one of the technical filters, so I'm posting here in case it could help someone else who is wondering why it is not even in Junk ...
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 9,384 10-21-2025, 10:13 AM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,374 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 6,373 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just received Pinephone - system crashes Zebulon Walton 12 22,248 11-13-2020, 05:45 PM
  Just discovered Pine64 ! - first Q philip_rhoades 4 9,497 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,144 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 205,764 01-15-2020, 12:46 PM
  How to handle a Pine64 correctly gbjensen 6 21,746 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 11,745 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 289,084 10-11-2018, 11:35 PM
Last Post: Technolab88
