Power Pine64 via GPIO
Hi there,
Is it possible to power Pine64 via GPIO headers?
Best,
Dzmitry
Yes, it should be possible, the Euler pin set has DC IN and Battery + connections.
https://drive.google.com/file/d/0B0cEs0l...VrZHM/view
Awesome, thanks
They now have a POE adapter for the Pine 64 which doesn't help you but is a good thing to know.
(01-25-2016, 11:17 PM)Opine Wrote: Yes, it should be possible, the Euler pin set has DC IN and Battery + connections.
I notice that in the pin assignment on the third page they have system LED and reset sw. Does that mean it possible to use the GPI0 to power on the board instead of soldering the tactile switches on? If so, what are the advantages to one over the other?
From what I read from a Linux thread I know that u can power it Via those pins and the advantage is that u can power it with more amps
Try always to use the shortest cable from psu to the pine64
Sent from my HUAWEI Y530 using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
Yes, the signals duplicate here. There is no particular advantage to one over the others, just for convenient and also also some POT module able to directly power on or reset Pine A64 board if the design choose to do so.
(03-15-2016, 05:34 AM)Zoidiano0 Wrote: From what I read from a Linux thread I know that u can power it Via those pins and the advantage is that u can power it with more amps
For power in point of view, thru Euler port power pin allows more amps. The original plan is allow POT module to supply power directly to Pine A64 board so that no need to supply power from micro USB port. One example like designing 20 watt class A amplifier on the POT board which require high power consumption where a high app power supply such as +12V 3A type is need, the POT schematic can drop +12V to +5V and supply to Pine A64 board.
What is the max Voltage in on the EULER bus? I have a 8v line in my case. Would that make the Pine run smoothly or fry it?
More like volts u need amps
Using a 5v 3.4 amps I thing I can be enough to make it work nice get a powergen charger or some similar that delivers that same or even more current cuz that is what makes the board work
By. Zoidiano0!
Installed:
Netbeans 8.1
(04-01-2016, 09:32 PM)Zoidiano0 Wrote: More like volts u need amps
100% wrong. The power problems most Pine users suffer from are related to voltage drops below a certain treshold.
Before you start telling funny stories please use the test points on the board to measure voltages and a powermeter to monitor consumption. Unless you add a lot of power hungry peripherals you will have a hard time to get the Pine consuming more than 1.5A.
You can use really demaning workloads that make use of heavily optimised code and compiler switches and you will need ACTIVE COOLING to exceed 2A (BTDT: be aware that some of the conclusions in this post are still to be verified or wrong) and will then need to power the Pine64 through the Euler connector.
The problem with Micro USB used for DC-IN is that the tiny contacts prevent providing more than 1.8A (by specs!) and that most if not all USB cables Pine64 backers use are simply crap to power a board (resistance too high).
Finally: Power ratings written on a PSU are also pretty worthless since the problem are still voltage drops and most higher rated PSUs show identical behaviour: In case you really increase consumption and would need the amps the PSU is rated for, the voltage drops below a treshold and the board will power down.
Everything well known since years (since the Raspberry Pi foundation unfortunately decided to use this crap Micro USB connector for DC-IN on the Raspberry Pi) and just here another example for the very same problem nearly all users are facing without knowing it since they believe in "more like volts u need amps" and similar nonsense:  https://www.loverpi.com/blogs/news/93532...comparison
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,404 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 38,481 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,523 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,497 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 29,051 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 11,020 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 52,504 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,699 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 29,363 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 57,408 10-05-2016, 06:43 AM
Last Post: Ghost
