256GB EMMC!
Hello there,
I am just wondering if Pinebook Pro can handle 256GB emmc?
Has anyone try that?
I haven't tried it, but it should be possible. Because not all socketed eMMCs use the same sockets, you'll need to do some research to be sure you're getting the right module that can fit the PBP board. IIRC there are several socketed eMMCs from Ameridroid that will fit the PBP and several other Pine products. Unfortunately, I cannot recall which specific ones, but hopefully it'll be a good starting place.
  eMMC failed Dendrocalamus64 9 7,036 11-12-2021, 11:08 AM
Last Post: Dendrocalamus64
  Upgrade eMMC card - boot problems alpopa 0 2,283 09-16-2020, 12:31 PM
Last Post: alpopa
  128GB eMMC support dgkPBP 7 8,790 09-08-2020, 07:36 AM
  Manjaro 20.06 requires multiple boots from eMMC to launch successfully on PBP Spectre 0 2,225 07-09-2020, 06:12 PM
Last Post: Spectre
  eMMC to USB adapter "very" slow at reading data talpa 3 5,271 07-08-2020, 08:55 AM
Last Post: talpa
  Internal installation of additional eMMC Besouro 7 8,541 06-06-2020, 09:33 PM
Last Post: xmixahlx
  Boot problems with new 128GB eMMC module Kareema 1 3,312 05-31-2020, 10:36 AM
Last Post: Kareema
Star Could you please add 128GB eMMC as a build option for this preorder? Dendrocalamus64 3 4,491 03-23-2020, 04:54 AM
Last Post: xmixahlx
  Emmc to MicroSD adapter won't fit in recessed slot of pbp sunjam 3 4,396 03-04-2020, 01:20 PM
Last Post: zaius
  Some power usage results of my Lexar NM520 M.2 2242 256GB NVMe Redbeard 0 2,723 02-07-2020, 04:42 PM
Last Post: Redbeard
