eMMC to USB adapter "very" slow at reading data
Hi I have the Pine64 eMMC to USB adapter.
When reading (using dd to /dev/null) from the 64GB eMMC that came with the Pinebook Pro I only get around 15 MB/s
With the 128GB module I seem to recall around 13 MB/s
The 128 GB module does give me 157MB/s when inside the Pinebook Pro it self
I have tried playing with the block size of the dd reads but it doesn't seem to do much difference.
The USB adapter might only use 1 bit transfers cutting the bandwidth in quarter, but that should possibly still give me 39MB/s
Does anyone have any tips for getting more performance out of the adapter?
Regards Visti Andresen
Adapter is only usb2!
Verzonden vanaf mijn iPhone met Tapatalk
(07-08-2020, 06:36 AM)roncromberge Wrote: Adapter is only usb2!
Yes, but shouldn't USB 2 theoretically (aka. marketing lies) be capable of ~50MB/s
According to the data sheet of the GL823 interface chip used it should support both 1 and 4 bit transfers.
However it also states a typical "SD/MMC Card Clock Frequency" of 48MHz i "High Speed Mode" which leaves one with 24MB/s of raw bandwidth to the eMMC if the interface runs in 4x mode.
I suppose protocol overhead could drop this down to 13-16 MB/s :o/
On a side note I'm getting around 50MB/s when dd'ing the data over ssh
(with a 1Gb/s ethernet connection with quite a lot of other traffic, and ssh did not use 100% of one CPU)
sudo dd if=/dev/mmcblk2 | ssh 192.168.9.30 dd of=/dev/null
965813760 bytes (2.0 GB, 1.8 GiB) copied, 37.0941 s, 53.0 MB/s
It seems that piping it through 'gzip -1' and 'zcat' only reduces the thoughput .
So perhaps I should just use the Pinebook Pro (booted of a SD card) as the eMMC reader
  256GB EMMC! sallyhaj 1 783 10-03-2023, 07:42 AM
Thumbs Up NVMe adapter, Great addition dachalife 2 1,793 11-28-2022, 12:56 PM
Last Post: dachalife
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,845 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,382 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  eMMC failed Dendrocalamus64 9 6,984 11-12-2021, 11:08 AM
  Upgrade eMMC card - boot problems alpopa 0 2,273 09-16-2020, 12:31 PM
Last Post: alpopa
  128GB eMMC support dgkPBP 7 8,739 09-08-2020, 07:36 AM
  Manjaro 20.06 requires multiple boots from eMMC to launch successfully on PBP Spectre 0 2,211 07-09-2020, 06:12 PM
Last Post: Spectre
  LTE adapter via NVMe grego 2 5,147 07-08-2020, 01:37 PM
Last Post: manawyrm
  Pro NVMe adapter Does not fit ! ? bcnaz 110 117,775 07-03-2020, 10:51 PM
Last Post: xmixahlx
