Emmc to MicroSD adapter won't fit in recessed slot of pbp
.jpg   microemmc.jpg (Size: 67.46 KB / Downloads: 389)
Will not fit!  I don't want to link to an order page as it might cause confusion.  Attempted with Odroid Emmc to MicroSD adapter.  Will not fit since the slot is recessed in the pbp
Solution:
You'll want to an Emmc to USB adapter instead.  I've had no trouble with those. Cheers.  Smile
I'm not sure I understand.
I have this adapter and it fits, it doesn't fit directly into the USB port but with the ton of microSD to USB adapters that come with SD cards it's not really a problem.
The adapter that doesn't fit is emmc to microsd.  I'm saying it will not click into the microsd slot.
I have a SmartFly eMMC to micro SD adapter that fits the PBP. I haven't tried to use it, but it clicks in place.
  256GB EMMC! sallyhaj 1 803 10-03-2023, 07:42 AM
Thumbs Up NVMe adapter, Great addition dachalife 2 1,817 11-28-2022, 12:56 PM
Last Post: dachalife
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,864 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,399 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  eMMC failed Dendrocalamus64 9 7,028 11-12-2021, 11:08 AM
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,410 04-02-2021, 06:45 PM
Last Post: tkudog
Shocked Is there a RIght and Wrong MicroSD? SpaceLord 4 5,063 03-15-2021, 09:17 PM
Last Post: dsimic
  microSD card stuck charlesnorris 7 7,998 11-19-2020, 05:11 AM
  Can't figure out where MicroSD space is kendew 4 5,773 09-23-2020, 07:25 PM
Last Post: Paulie420
  Upgrade eMMC card - boot problems alpopa 0 2,282 09-16-2020, 12:31 PM
Last Post: alpopa
