Disassembling PineBook Pro Docking Deck (due to disappeared microSD card)
Question
unfortunately a microSD card "was eaten by" / disappeared inside the "Docking Deck".
This happened because I was careless and on the other hand because the slots and sockets/plugs in the "Docking Deck" housing were not well aligned.
The question now is, how the "Docking Deck" housing can be opened (without damage) to remove the loose, freely moving SD card.
Any advice is welcome, thanks.
Gritibaenz
Big Grin
(01-16-2021, 09:39 AM)gritibaenz Wrote: Hello,
Gritibaenz
Solved. See attachment.
.pdf   opening_PineBookPro_DockingDeck.pdf (Size: 74.05 KB / Downloads: 456)
Seems like it involves some destructive activity?
I've also had the same issue (microSD card disappeared), and I want to thank @gritibaenz for this thread!
I want to add that there is non-destructive way to open the case, just heat the black cover (I've used my wife's hair dryer, no special hot air gun is needed) and pry it after the glue melts:
Then the housing can be opened.
It was a little bit weird that the two screws are different sizes, but anyway. Everything works after the reassembly.
Exact same oopsie.  But the larger issue is how to bend stuff so that it lines up properly?  I was too afraid to just start prying.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 394 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 304 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 243 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 580 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,036 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 129,080 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 5,915 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,308 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 134,099 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,853 10-21-2022, 07:57 AM
Last Post: dachalife
