128GB eMMC support
Does the Pinebook Pro support the 128GB eMMC?
I ordered one, flashed it with the latest Manjaro. It will walk you through the initial setup (name, pswd, location, etc) but fails to reboot when completed. If I power down and reboot, it just hangs.
Thanks.
I think you answered your own question. It seems you have a software problem.
Yes, any Pine emmc is supported in the PBP (The very first public batch actually shipped with that size. I use mine and have not have an issue with it yet.)
How are you imaging your emmc?
(08-31-2020, 06:44 AM)tophneal Wrote: Yes, any Pine emmc is supported in the PBP (The very first public batch actually shipped with that size. I use mine and have not have an issue with it yet.)
Interesting. I wasn't sure if it was supported or not.
I'm using a USB/emmc writer with Etcher. I flashed it twice using Manjaro ARM with KDE (Plasma); no joy.
You could try using the Manjaro SD>eMMc installer image, or try going back a month or two in the Manjaro release images and trying one of them. Anything 20.02+ should be good (though i have heard of people having issues with 20.06 images.
Just re-downloaded 20.08, re-flashed, installed; no joy. It goes through all the configuration questions and reboots. I get three solid lines about a quarter inch wide from top to bottom of the screen; kind of like the logo is streched out.
However, when I power it off and reboot, I get the manjaro logo; spinning dots then it stops. Wait about a minute+, and I get the logon!
I can logon ok. Power down and back up OK.
Strange.
(08-31-2020, 08:18 AM)dgkPBP Wrote: Just re-downloaded 20.08, re-flashed, installed; no joy. It goes through all the configuration questions and reboots. I get three solid lines about a quarter inch wide from top to bottom of the screen; kind of like the logo is streched out.
Strange.
OK, the 128GB eMMC is working...but if I try to reboot from the running system, it hangs with a distorted logo (three lines from top to bottom of screen). If I manually power down, it will boot up just fine.
It also will not boot from a USB or SD. USB does nothing and the SD will hang wilh spinning dots. If I hit escape, I get a blank screen with ablinking cursor. IF I power down, remove the SD card and boot, it works fine.
I guess I can live with it, but it's troubling. I'd love to see a diagnostic image we could boot and run basic tests (memory test, re-flash boot, etc).
Thanks.
It has been reporteda in another thread that the Uboot that came with the original Debian might solve this problem.
  256GB EMMC! sallyhaj 1 729 10-03-2023, 07:42 AM
  128GB Module not booting on 2022 Pinebook Pro batch JessicaQ 0 1,019 08-12-2022, 06:41 AM
Last Post: JessicaQ
  eMMC failed Dendrocalamus64 9 6,800 11-12-2021, 11:08 AM
Last Post: Dendrocalamus64
  Upgrade eMMC card - boot problems alpopa 0 2,238 09-16-2020, 12:31 PM
Last Post: alpopa
  Manjaro 20.06 requires multiple boots from eMMC to launch successfully on PBP Spectre 0 2,178 07-09-2020, 06:12 PM
Last Post: Spectre
  eMMC to USB adapter "very" slow at reading data talpa 3 5,165 07-08-2020, 08:55 AM
Last Post: talpa
  Internal installation of additional eMMC Besouro 7 8,379 06-06-2020, 09:33 PM
Last Post: xmixahlx
  Boot problems with new 128GB eMMC module Kareema 1 3,245 05-31-2020, 10:36 AM
Last Post: Kareema
Star Could you please add 128GB eMMC as a build option for this preorder? Dendrocalamus64 3 4,399 03-23-2020, 04:54 AM
Last Post: xmixahlx
  Emmc to MicroSD adapter won't fit in recessed slot of pbp sunjam 3 4,307 03-04-2020, 01:20 PM
Last Post: zaius
