How to write the the external SD card with Abword?
I have listed here problems with Abiword on the Pinephone which make it impossible to use Abiword with postmarkedOS stable:
https://forum.pine64.org/showthread.php?tid=18639
https://forum.pine64.org/showthread.php?tid=18638
The only option left here is to change the distro from postmarkedOS stable to Postmarket OS Phosh Edge, which is a lot of work. But why can I not write a file to the exernal SD card with Abiword? I can save a file to the internal SD card with Abiword, but not to to the exernal SD card. Is there a way to do it or is it an issue that Abiword cannot do this?
  How can I get the permissions to write to the external SD card ...? Peter Gamma 9 1,664 10-20-2023, 12:32 PM
Last Post: Peter Gamma
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 2,019 08-25-2023, 02:05 AM
  Help how to mount SD-Card chadwick 8 7,659 11-30-2021, 11:12 PM
Last Post: chadwick
  PP boots into factory test even if flashed sd card is inserted hapster 5 6,477 04-13-2020, 02:34 PM
Last Post: MartijnBraam
  terminal command for sd card size pnphn 5 6,709 04-02-2020, 12:51 PM
Last Post: someGermanGuy
