pinetab2 hardware is not very good
I’ve been successfully using my PT2 daily at work, since it’s been released; it’s become a replacement for my PBP, due to the smaller form factor.
I don’t mind the tethering/using my own hot-spot, as once I connect to public/government WIFI, my privacy rights are gone according to the EUGDPR and everything is monitored.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
I use mine for Youtube, reading kindle books (Waydroid), web browsing, etc. It feels a little on the sluggish side, but not unusably so as long as I try to be smart about what I run on it. Ubuntu Touch felt more responsive to me (and already ships with a wifi driver that can be enabled with one command), so I've just been running that off the SD card.
I did overclock my Pinetab 2, which seemed to help a little. These Cortex A55 cores just aren't made to be fast, they're marginally better than the Cortex A53 (which helps), but they're not P-cores. I did publish a guide here on the forums on how to overclock it if anyone else wants to try (of course, this is at your own risk, but it was a fairly easy overclock for me and has given me no stability or thermal problems).
  Pinetab2 not starting Corconegre 6 1,608 03-18-2024, 10:47 AM
Last Post: zogkarndon
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 411 03-16-2024, 11:56 AM
Last Post: scottgr
Information nvme ssd and open pinetab2 snock 0 217 01-12-2024, 06:37 PM
Last Post: snock
  Pinetab2 screen removal Corconegre 5 1,351 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 609 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 336 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 524 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 2,888 09-15-2023, 11:45 PM
Last Post: Ome Ko
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 1,733 09-06-2023, 07:43 PM
Last Post: bacon_dude
  PineTab2 screen won't turn back on until reboot KelsonV 3 1,057 08-23-2023, 09:08 AM
Last Post: diederik
