PineTab2 screen won't turn back on until reboot
This is a different problem than the one that's been reported where the screen just won't turn on at all.
It's also different from suspend/hibernate not working, because the system is still running and reachable via SSH.
The screen is turning off after a period of inactivity (even though I've set power management not to turn off the screen) and won't turn back on until I reboot the tablet. The keys light up when I press them. The USB network adapter I have shows activity. I can even SSH in from another computer.
But the screen *does* come back on after reboot, whether I use the command line through an SSH session, or whether I just hold the power button down until it shuts off, then power it on again.
I'm currently using LxQt on the factory-shipped danctnix updated to the latest with pacman.
Has anyone else seen this? Any solution, or a tip for finding what else might be powering off the screen if my desktop session isn't doing it?
I haven't use LxQT for a while, but I assume it runs X and not Wayland, correct? If so, try to SSH into your device and run
$ xset -q
What do you get?
Thanks for pointing me in the right direction! Yeah, LXQT is running under X.  I had to script a loop to repeatedly save that output to a log, since the remote SSH session couldn't talk to the main X session, but what I found is:
  1. DPMS is enabled, with the standby, suspend and off timeouts at 600 -- which it shouldn't be, because LXQt is set to not standby or suspend, but....
  2. There is a bug in LXQT's power management where it doesn't always update DPMS's settings.
  3. DPMS sees the monitor as off.
I also verified that the timeouts, lock screen etc. do still work correctly under Wayland on my device, so that's good to know!
That gives me a couple of approaches (workarounds, or manually installing the newer version, etc.) to prevent the problem of it turning off when I don't want it to. (I really do not miss all that messing with X configuration back in the old days, but hey, you gotta do what works.)
Then I need to figure out how to get it to turn back on. If LxQt's own power management works right (except for the dpms issue), then problem solved. It not, I figure I'll experiment with blank, standby, and suspend to see which ones (if any) the display recovers from.
For the record: Full output of xset -q after the display turns off:
Keyboard Control:
  auto repeat:  on    key click percent:  0    LED mask:  00000000
  XKB indicators:
    00: Caps Lock:  off    01: Num Lock:    off    02: Scroll Lock: off
    03: Compose:    off    04: Kana:        off    05: Sleep:      off
    06: Suspend:    off    07: Mute:        off    08: Misc:        off
    09: Mail:        off    10: Charging:    off    11: Shift Lock:  off
    12: Group 2:    off    13: Mouse Keys:  off
  auto repeat delay:  500    repeat rate:  33
  auto repeating keys:  00ffffffdffffbbf
                        fadfffefffedffff
                        9fffffffffffffff
                        fff7ffffffffffff
  bell percent:  0    bell pitch:  400    bell duration:  100
Pointer Control:
  acceleration:  2/1    threshold:  4
Screen Saver:
  prefer blanking:  yes    allow exposures:  yes
  timeout:  600    cycle:  600
Colors:
  default colormap:  0x20    BlackPixel:  0x0    WhitePixel:  0xffffff
Font Path:
  built-ins
DPMS (Display Power Management Signaling):
  Standby: 600    Suspend: 600    Off: 600
  DPMS is Enabled
  Monitor is Off
(08-21-2023, 03:23 PM)KelsonV Wrote: The screen is turning off after a period of inactivity (even though I've set power management not to turn off the screen) and won't turn back on until I reboot the tablet. The keys light up when I press them. The USB network adapter I have shows activity. I can even SSH in from another computer.
I'm using a self-assembled Debian (Trixie) system with self-compiled kernel running KDE, and I've run into this problem too.
AFAICT it's all running Wayland, perhaps except SDDM.
I haven't found a solution yet, but I'm very much interested in one.
Haven't verified if it's also present in the Danctnix system though.
  Pinetab2 not starting Corconegre 6 1,602 03-18-2024, 10:47 AM
Last Post: zogkarndon
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 401 03-16-2024, 11:56 AM
Last Post: scottgr
  pinetab2 hardware is not very good lmartin 11 2,331 01-13-2024, 03:45 AM
Last Post: Darth-Apple
Information nvme ssd and open pinetab2 snock 0 213 01-12-2024, 06:37 PM
Last Post: snock
  Pinetab2 screen removal Corconegre 5 1,344 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 603 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 331 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 521 10-14-2023, 05:48 PM
Last Post: lockedpotato
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 539 09-28-2023, 01:06 PM
Last Post: dynobang
  pinetab2 booting when adapter connected Ome Ko 16 2,864 09-15-2023, 11:45 PM
Last Post: Ome Ko
