Pinetab2 Keyboard Issues
Exclamation
I can't really tell if this is a software issue or a hardware issue. When I move the tablet around sometimes the keyboard just turns off and won't turn back on until I remove the tablet from the cover and put it back in. It does the same thing when I close the cover too. It works fine when I have it still. Sometimes when I take it out and in (when it turns off) the backlight will turn back on the keys and touchpad still won't do anything (and then I have to do it again). Is this common or just mine?
  Pinetab2 not starting Corconegre 6 1,600 03-18-2024, 10:47 AM
Last Post: zogkarndon
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 398 03-16-2024, 11:56 AM
Last Post: scottgr
  pinetab2 hardware is not very good lmartin 11 2,315 01-13-2024, 03:45 AM
Last Post: Darth-Apple
Information nvme ssd and open pinetab2 snock 0 209 01-12-2024, 06:37 PM
Last Post: snock
  Pinetab2 screen removal Corconegre 5 1,342 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 600 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 328 12-22-2023, 01:23 PM
Last Post: FortunateFowl
  Keyboard issue mshelby 2 593 11-22-2023, 09:14 AM
Last Post: mshelby
  pinetab2 booting when adapter connected Ome Ko 16 2,846 09-15-2023, 11:45 PM
Last Post: Ome Ko
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 1,724 09-06-2023, 07:43 PM
Last Post: bacon_dude
