Booting from SD card on Pinetab2
(07-27-2023, 08:33 PM)samochimaaron Wrote: I recently received a Pinetab2...
Every time I tried booting, it booted Danctnix. When I plugged the UART adaptor into the bottom USB C port and turned the switch to the "on" position, nothing at all booted. The same thing happened when I tried booting Mobian.
Does anyone have any suggestions?
IIRC, the Danctnix image provided from the factory has an u-boot version which doesn't boot from SDcard when it's present.
If you login to the danctnix image and update (pacman -Syu), you should get one which does.
I think that you first need to set the switch to the "on" position the first time, but after that it'll default to booting from SDcard when a suitable system is present on it.
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 195 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 347 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 832 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 697 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 1,360 09-25-2023, 08:29 PM
Last Post: bluemage
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 962 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  pinetab 2 not booting ajhiii070 5 1,828 08-07-2023, 01:46 PM
Last Post: r.aliaskarov
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,141 07-14-2023, 03:09 AM
Last Post: gregb49
  PineTab2 virtual keyboard: symbols instead of numbers clemfandango 5 2,003 07-12-2023, 05:32 AM
Last Post: mtomaschett
  Pinetab2 not booting. elix 10 2,949 07-09-2023, 02:42 PM
Last Post: elix
