Manajaro Plasma 6 files break unstable updates, 6-30
The unstable branch of Manjaro Plasma is not updatable now. Plasma 5 files are missing from the update.
So actually, the thorough going "pacman -Syyuu" update can not be used now.
(07-01-2023, 02:55 PM)mburns Wrote: So actually, the thorough going "pacman  -Syyuu" update can not be used now.
The testing and stable branches of Manjaro Plasma are not updatable also. I see work being done on the unstable branch, maybe it will be updatable today yet.
The unstable branch of Manjaro Plasma is still not updatable on the Pine Phone Pro as of July 18. After software updates newer than June 29, the Plasmashell interface will not start.
Of course, the Tow-Boot option of starting Mobian Phosh instead is very usable.
(07-18-2023, 08:54 AM)mburns Wrote: The unstable branch of Manjaro Plasma is still not updatable on the Pine Phone Pro as of July 18. After software updates newer than June 29, the Plasmashell interface will not start.
I am not sure but I think Manjaro Plasma project is stopped or at least slowed down significantly after Dan left the project.
New packages are coming when upstream does something but I am not sure is there anyone who is actually testing and would make sure everything works.
I think at the moment it might be easier to use Arch or Postmarketos if you want to use Plasma.
Today's update of Manjaro Plasma will not boot. Here is a script I will use in order to continue updating without a reinstall. I run it on a Mobian installation on the optional microSD chip. I run the script from root on Mobian with Manjaro mounted on /home/d2. Afterwards I am in the Manjaro environment, but safely on the Mobian kernel.
Rescuelil
#! /bin/bash
cd /home/d2/root
mount /dev/mmcblk2p1 /home/d2/boot
mount --bind /proc /home/d2/proc
mount --bind /sys /home/d2/sys
mount --bind /dev /home/d2/dev
mount --bind /run /home/d2/run
chroot /home/d2
  [WIP] KDE Plasma Mobile 6.0 Builds & Ports dorkydev 5 685 04-15-2024, 08:08 AM
Last Post: u-kidjp
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 661 11-09-2023, 07:39 AM
Last Post: mburns
  Manjaro Plasma unstable branch glitch mburns 2 1,079 06-21-2023, 08:03 AM
Last Post: mburns
  Is Manjaro Plasma stable for anyone? projectcato 120 53,757 04-18-2023, 08:26 PM
Last Post: mburns
  Plasma Mobile Taskbar / Navigation Bar is Missing & Upper Panel X0X0X0X0X0 1 1,318 11-24-2022, 07:19 AM
Last Post: mburns
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 1,103 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Monjaro Plasma Cell Network and Data not working properly maiyuzhe 2 1,597 09-24-2022, 12:15 AM
Last Post: maiyuzhe
  Waydroid on PinePhone Pro PPP (Stock Manjaro Plasma) mhedhli 7 6,434 09-18-2022, 06:54 PM
Last Post: nroth
  Offline Updates Error dgiffin 7 4,689 06-30-2022, 02:19 PM
Last Post: magdesign
  Manjaro Plasma Beta 11 sleep issue after 3/22 update Fred Zyphal 6 3,973 05-22-2022, 12:37 PM
