PineTab2 Touchscreen
I received my PineTab2 a couple of days ago and I really enjoy the product. The one thing I've noticed is the touchscreen is not responding. I checked the settings and it's enabled. Is there a known issue with the touchscreen or something I'm missing? Any assistance will be greatly appreciated. Thank you.
Mine seemed to work but then, despite the cursor moving around, it wouldn't respond to tapping on anything, so I couldn't hit a "button" of any kind.
I forcibly shut it down (holding power), and when I restarted it worked normally again and I was able to get around some.
it doesn't get happy
it doesn't get sad
it just runs programs
Re: touchscreen not responding, I noticed that, too.
Like you, the first thing I checked was System Settings -> Input Devices -> Touchscreen -- and it was still enabled.
Later I was in System Settings -> Workspace Behavior -> General Behavior, where there's a "Touch Mode" option. The "info" button beside "Automatically enable as needed" (the default setting) said that Touch Mode would be activated whenever it noticed no mouse or touchpad. My guess was it saw me using those and disabled the touchscreen.
I changed it to "Always enabled." Now my touchscreen always works. And the added benefit is it made the buttons at the top of each window bigger for convenient fingertapping.
While I was at it, I changed Settings -> Window Behavior -> Window Management -> Window placement to be "Maximized" so that when I launch applications they automatically go full-screen. Lookin' for that tablet behavior.
I appreciate the input. Touchscreen is working as I would expect. Thanks again guys!
It looks to me as though, particularly after sleeping, the touchscreen often stops working. Just happened for the 2nd or 3rd time. Hard reset fixes it. Sounds like a bug to work out in the OS and not a proper showstopper.
it doesn't get sad
  New PineTab2 dRateNWAytORy 0 27 Yesterday, 04:31 PM
Last Post: dRateNWAytORy
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 234 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 403 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 880 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 748 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 1,443 09-25-2023, 08:29 PM
Last Post: bluemage
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,019 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Booting from SD card on Pinetab2 samochimaaron 10 3,152 08-23-2023, 09:38 AM
Last Post: diederik
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,242 07-14-2023, 03:09 AM
Last Post: gregb49
  PineTab2 virtual keyboard: symbols instead of numbers clemfandango 5 2,101 07-12-2023, 05:32 AM
Last Post: mtomaschett
