Can't write to SD card w/ Adapter
I'm trying to update the image on my MicroSD card, but its telling me its read only. I looked at the adapter, and there is the "Lock" text and a hole where a switch should be, but there is no switch.
Help??
I do it live!
Ditch the adapter and use a card reader that reads the micro-SD directly? They're cheap if you do a little shopping.
I don't use the adapters often at all (in fact, if you're US based, send me your address and I'll send a couple absolutely free of charge.. Smile..), the one I'm looking at has a slider to "lock".
(07-23-2016, 01:40 PM)DonFL Wrote: Ditch the adapter and use a card reader that reads the micro-SD directly? They're cheap if you do a little shopping.
Well both my Macs have SD card readers built in, so the adapter is handy. I ended up ordering another MicroSD card which comes with an adapter, since I want a second card for testing.
Yeah looks I have a bum one. There is place for the lock slider, it just isn't there!
I do it live!
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 6,881 05-19-2023, 07:43 AM
Last Post: crocspot
Exclamation Can't boot when SD card inserted kivox 5 13,361 03-15-2020, 06:00 AM
Last Post: kivox
Photo Daughter Card SBC for P64 blue 5 12,318 08-22-2017, 07:51 AM
Last Post: blue
  read/write gpio in c example? ealbers 1 6,973 07-23-2017, 05:53 AM
Last Post: MarkHaysHarris777
  Tool chain to write Pine 64 linux apps on a Windows Dev machine SvdSinner 2 7,629 07-17-2017, 11:37 PM
  Pine64 $15 card killed my $120 keyboard exa 22 46,077 01-04-2017, 09:01 AM
Last Post: skenn_ie
  overlapping partitions issue with resize of 8GB image put on 16GB sd card dkryder 10 20,520 10-05-2016, 11:32 AM
Last Post: dkryder
  SD card recovery TeaPack 8 14,878 08-07-2016, 07:35 AM
Last Post: xalius
  missing SD card xj-boonie 4 10,143 07-13-2016, 12:22 PM
  128GB Card OS? mesaxi 12 27,252 07-12-2016, 11:59 PM
Last Post: Tarjei85
