Pinephone Pro Earpiece is not working, need help
Some time ago I noticed that I no longer hear my peer during a call. After some investigation and trying different images I installed factory test image from here: https://wiki.pine64.org/wiki/PinePhone_P...e_Checking
No sound can be heard during earpiece test even there . So I come to conclusion that Earpiece is not working on my device at all. It was working previously, sadly I cannot confirm exact point when the issue started.
Is there anything I can do with that?
(03-02-2023, 01:52 PM)silverwing Wrote: Some time ago I noticed that I no longer hear my peer during a call. After some investigation and trying different images I installed factory test image from here: https://wiki.pine64.org/wiki/PinePhone_P...e_Checking
I am not sure does this help but for me some things cause issues with earpiece audio:
These all might be coinsidents so take them as they are (some stranger from the internet is just telling you something Big Grin )
- When my wifi/bluetooth killswitch was off it somehow cause pulseaudio suspending really fast
- Newer kernels cause audio issues for me on Mobian, PMOS and Manjaro
- Before I upgraded Tow-Boot to latest version audio was not that reliably functioning (no idea what my Tow-boot version was but I received my PPP like three weeks ago)
- If I suspend as root it will cause audio issues (for example with sleepwalk scripts or similar)
Hope you will get working audio back Smile
If the factory test image also does not work, you might also have a faulty part.
Measure the resistance between the pins. If there is no connection, it's dead.
I created a thread for this exact issue, that I just fixed today: https://forum.pine64.org/showthread.php?tid=18075
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 743 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 387 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,130 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 223 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,783 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,167 11-18-2023, 07:25 AM
Last Post: crocspot
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 2,643 08-13-2023, 04:50 AM
Last Post: fxc
  Pinephone pro packet injection for internal wifi chipset covar 1 807 08-13-2023, 04:40 AM
Last Post: fxc
  PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? jovval 0 516 07-09-2023, 09:03 PM
Last Post: jovval
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,637 03-26-2023, 02:55 AM
Last Post: tux_life
