My PinePhone Pro does not read the micro SD card at all.
Hi!
I tried booting from SD card as indicated here: https://wiki.pine64.org/wiki/PinePhone_Pro#Boot_from_microSD_card_temporarily.
I also tried holding the RE button.
Nothing works and the operating system does not detect any SD card.
The microSD card is inserted all the way...
[Image: gXPySj4G]
[Image: 7GmC3ZWs]
(03-23-2023, 03:34 PM)tux_life Wrote: Hi!
[Image: gXPySj4G]
[Image: 7GmC3ZWs]
RE button is not necessary in that case, holding "volume down" at boot is sufficient as it seems that you bought your phone after July 2022. Though the OS not detecting the card is not a good sign, booting from it will not work in that case either.
The card looks inserted correctly and it's a very basic functionality which is expected to work, unless something is broken (card, card reader).
Did you try a different card? This one looks like it already went through a lot of things.
(03-23-2023, 06:24 PM)fxc Wrote: Did you try a different card? This one looks like it already went through a lot of things.
I tried with three different ones.
Looks like a defective board then. You might want to check if the microSD card detection pin broke off by looking from the side. Would suggest to open a ticket under https://support.pine64.org.
Thank you!!!
I solved the problem by lifting the pins.
The card reader works now and I can boot from SD.
Thanks and sorry for my bad english.
Thank you!!!
On a side note, mind that you can also flash the eMMC using Tow-Boot's USB Mass Storage mode (hold volume up at boot).
Thank you!!!
I have this same problem.  I figured it's a problem with the reader (i.e. the hardware), but haven't fixed it, yet.  Support was no help.
@tux_life  You "lifted the pins"?  How?  What did you do?  This seems as if it maybe a solution for me, too.
(03-25-2023, 11:43 AM)_radv_ Wrote: I have this same problem.  I figured it's a problem with the reader (i.e. the hardware), but haven't fixed it, yet.  Support was no help.
In my case it may be that I myself somehow damaged the reader.
Anyway...as suggested by fxc I looked at the pins and noticed some were down. I raised them up a bit with a small screwdriver. My English is very bad, so I hope I was clear.
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 735 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 383 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,121 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 219 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,781 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,163 11-18-2023, 07:25 AM
Last Post: crocspot
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 2,638 08-13-2023, 04:50 AM
Last Post: fxc
  Pinephone pro packet injection for internal wifi chipset covar 1 803 08-13-2023, 04:40 AM
Last Post: fxc
  PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? jovval 0 515 07-09-2023, 09:03 PM
Last Post: jovval
  Anyone yet received replacement sim/sd card holder tckosvic 19 9,007 06-16-2023, 12:20 PM
Last Post: fxc
