Broke Screen and fix it - Up Swipe not working.
Dropped it on the corner and broke the screen.
Replaced it and the "slide up to unlock" is not working now (will not slide up!).
Any suggestion or recommendations?
As in you mean only touchscreen is not working after screen replacement?
Take it apart, look for damage and reseat / reattach ribbon cables once again.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
(02-11-2023, 11:47 PM)RTP Wrote: As in you mean only touchscreen is not working after screen replacement?
No touchscreen... Re-did as you recommended.  Nothing is working as far as touchscreen is concerned.  Re-flashed to latest Plasma Mobile image, still nothing.   Will try w. Phosh image but not expecting much.  Maybe the drop broke something HW wise?
**----> Didn't work!!! Going to take it apart again. I Ordered a new ribbon cable (hoping!)... If that doesn't work then probably HW issue.
**Note - If anyone knows anything about touchscreen diagnostics...feel free to chime in.
**> Still awaiting parts to arrive.
&&& - > Part came in...still no luck! Does anyone know anything about touchscreen diagnostics!! Next step is to send the screen back.
  Pinephone pro replacement lcd screen Linuxuser3 0 5 2 hours ago
Last Post: Linuxuser3
  PinePhone Pro Black Screen CrimsenRaven 2 402 03-16-2024, 11:40 AM
Last Post: tmoj
  Pinephone Pro Screen Protector jydoxcen 11 1,470 12-21-2023, 07:58 AM
Last Post: zetabeta
  Camera stops working after resume from suspend jchw 0 645 09-06-2023, 08:39 AM
Last Post: jchw
Thumbs Up PinePhone Pro working adamfowleruk 2 2,304 02-16-2023, 06:47 AM
Last Post: Piotr
  Broke my screen Barugon 7 4,211 10-11-2022, 01:30 PM
Last Post: Juan_Mann
  SMS Receive suddenly stopped working grinzie 6 3,279 10-01-2022, 12:44 PM
Last Post: grinzie
  Internet is not working on Pine Pro phone caroljames972022 0 883 09-16-2022, 06:25 AM
Last Post: caroljames972022
  PinePhone Pro working on Lapdock using Arch Plasma hockleyj 5 3,021 05-27-2022, 05:18 PM
Last Post: hockleyj
  Can this stop my sim from working? For_lack_of_a_better_name 1 1,094 04-12-2022, 02:00 AM
Last Post: wibble
