SMS Receive suddenly stopped working
My carrier is T-Mobile USA. On 2022-08-08 (six days ago) I stopped receiving texts, though I did not realize it until 2022-08-12 (yesterday).
During that time, texts I sent were received, and phone calls worked, both incoming and outgoing.
I am certain that I did not change anything (software, firmware, etc.) around the time SMS Receive stopped working.
Today I tried several things to solve the problem, but the one that finally worked was switching ADSP firmware to 30.006.30.006.
After that, I received missing texts.
I can't find the thread with the specific command right now, but you can use mmcli to clear the incoming cache. I had the same problem a couple months ago, and clearing all ten slots fixed it.
(08-17-2022, 11:49 AM)DerpABerp Wrote: I can't find the thread with the specific command right now, but you can use mmcli to clear the incoming cache. I had the same problem a couple months ago, and clearing all ten slots fixed it.
Thanks for the suggestion. The problem persists (confirmed not receiving some texts).
I found the link: https://forum.pine64.org/showthread.php?tid=9687
Flushing the cache makes no difference.
    sudo mmcli -m any --command='AT+CMGD=?'
gives:
+CMGD: (0),(0-4)
    sudo mmcli -m any --command='AT+CMGD=0,4'
gives:
+CMGD: (),(0-4)
Still not receiving texts from test phone.
I found the thread with the command that fixed it on my phone a few months ago.
https://forum.pine64.org/showthread.php?tid=10014
$ sudo mmcli -m 0 --messaging-delete-sms=1 # Repeat with 1 through 10 to delete all of the messages
(08-14-2022, 07:07 PM)grinzie Wrote: My carrier is T-Mobile USA. On 2022-08-08 (six days ago) I stopped receiving texts, though I did not realize it until 2022-08-12 (yesterday).
Hey, how did you switch ADSP SW, I have this issue with missing texts
(08-19-2022, 04:25 PM)DerpABerp Wrote: I found the thread with the command that fixed it on my phone a few months ago.
I use my Pinephone Manjaro since november 2020, I do all the Manjaro ARM phosh update, everthing was working good.
But since 1 week, I can't receive sms ?
I reflash Manjaro ARM phosh pinephone beta 24, nothing change.
I flash to Manjaro ARM phosh pinephone beta 27, and nothing change...
I can call > I can get a call.
I can use internet with wifi.
I can send sms > I can't receive sms.
Thanks a lot DerpABerp, now it work again. Smile
I think clearing the cache, as mentioned elsewhere in this thread, is the proper solution, but ADSP SW and instructions to update it are on biktorgj's PinePhone Modem SDK, on the Releases page: https://github.com/the-modem-distro/pine...tag/0.6.81
Search for ADSP
  Camera stops working after resume from suspend jchw 0 558 09-06-2023, 08:39 AM
Last Post: jchw
Thumbs Up PinePhone Pro working adamfowleruk 2 2,221 02-16-2023, 06:47 AM
Last Post: Piotr
  Broke Screen and fix it - Up Swipe not working. iwm 2 1,251 02-12-2023, 03:44 PM
Last Post: iwm
  Can't make or receive calls 1G1R 1 1,532 02-10-2023, 01:10 AM
Last Post: Piotr
  Internet is not working on Pine Pro phone caroljames972022 0 828 09-16-2022, 06:25 AM
Last Post: caroljames972022
  PinePhone Pro working on Lapdock using Arch Plasma hockleyj 5 2,883 05-27-2022, 05:18 PM
Last Post: hockleyj
  Can this stop my sim from working? For_lack_of_a_better_name 1 1,033 04-12-2022, 02:00 AM
Last Post: wibble
