org.kde.plasma.core not installed (Manjaro)
My PBP crashed during an upgrade and now the desktop/GUI won't load. I get an error message that says the current theme cannot be loaded and that the error is file:///use/share/sddm/themes/breath/Main.qml:26:1:module "org.kde.plasma.core" is not installed.
I went into a tty and did pacman -S to a lot of kde stuff (plasma-framework, then others when there was no change on reboot).
How do I either revert or replace what is bad to get my desktop back?
  Manjaro Sway Theme Broken Eighty8 1 280 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,754 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 328 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,141 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,217 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 891 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,019 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,969 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 765 08-18-2023, 02:06 AM
Last Post: juliamenendez
