Pinetime Screen issue after bootloop troubles
(09-15-2022, 05:40 AM)wibble Wrote: The heart rate sensor window is clear plastic, stuck to the back cover. Depending on how well I align it when I put the back cover on it sometimes looks like there's some pressure on the back, raising the middle of the window slightly. It's seem most easily if you view at an angle to see the distortion of the reflection on the window. I could imagine this leading to a leak over time. Since I stuck the back on myself I've assumed it will leak, but between sweat and rain it's been ok so far.
I believe @Spater had a sealed unit, so this may indicate some manufacturing check that needs to be performed during assembly.
The erosion definitely looks as if it came through the area where there is the heart rate window. The rest of the PCB looks corrosion free.
It still may not explain the display though.
@Spater How did you clean the green corrosion? Ideally you try some non-conductive anti-corrosion cleaner (maybe pure alcohol?).
Thanks @wibble for looking into the assembly of the heart rate sensor and case fitting.
Quote:I believe @Spater had a sealed unit, so this may indicate some manufacturing check that needs to be performed during assembly.
@barray you are right, I have the Sealed version of Pinetime.
Quote:How did you clean the green corrosion? Ideally you try some non-conductive anti-corrosion cleaner (maybe pure alcohol?).
I used pure Isopropyl alcohol to clean it.
Quote:It still may not explain the display though.
Took a look at the back of screen, could the spot in the red circle (see attached picture) be due to some kind of overheating?
Looks like there's something on the back of the board in the same location, but it's out of focus. What is it?
  PineTime at FOSDEM jmlich 5 886 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 272 01-31-2024, 11:57 AM
Last Post: tynstar
  Bluetooth Connection Issue Orionbelt 2 2,164 11-24-2023, 05:27 PM
Last Post: BrianPineFan
  PineTime and Amazfish on Ubuntu Touch jmlich 1 787 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 14,033 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,563 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,263 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 6,933 02-11-2023, 09:30 AM
Last Post: alexmitroff
  Screen stopped working properly pcfreak9000 3 1,702 01-18-2023, 04:28 PM
  PineTime beginner MV1791 2 2,251 01-09-2023, 11:52 PM
Last Post: Canyonless
