Battery problem with a Pinephone keyboard and Mobian
I am using Manajro ARM (Phosh) and I have the same problem.
Quote:uname -r
Linux manjaro-arm 6.0.2-1-MANJARO-ARM #1 SMP PREEMPT Wed Oct 19 06:43:45 UTC 2022 aarch64 GNU/Linux
Previously, it used to show 66% on a full charge,
but after updating to the latest version, it shows 33% on a full charge.
Perhaps the latest version of Mobian (Weekly) will also show 33% on a full charge.
I do not know how to correct the problem.
I wish I had a better solution....
Quote:cat /sys/class/power_supply/ip5xxx-battery/uevent
     1  POWER_SUPPLY_NAME=ip5xxx-battery
     2  POWER_SUPPLY_TYPE=Battery
     3  POWER_SUPPLY_STATUS=Not charging
     4  POWER_SUPPLY_CHARGE_TYPE=N/A
     5  POWER_SUPPLY_CHARGE_BEHAVIOUR=auto
     6  POWER_SUPPLY_HEALTH=Safety timer expire
     7  POWER_SUPPLY_CAPACITY=86
     8  POWER_SUPPLY_CALIBRATE=187
     9  POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000
    10  POWER_SUPPLY_VOLTAGE_NOW=4016064
    11  POWER_SUPPLY_VOLTAGE_OCV=4166452
    12  POWER_SUPPLY_CURRENT_NOW=-7460
    13  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=2300000
    14  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=3100000
    15  POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE=4228000
    16  POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE_MAX=4242000
Quote:cat /sys/class/power_supply/axp20x-battery/uevent
     1  POWER_SUPPLY_NAME=axp20x-battery
     3  POWER_SUPPLY_PRESENT=1
     4  POWER_SUPPLY_ONLINE=1
     5  POWER_SUPPLY_STATUS=Charging
     6  POWER_SUPPLY_CHARGE_BEHAVIOUR=auto
     7  POWER_SUPPLY_VOLTAGE_NOW=4249000
     8  POWER_SUPPLY_CURRENT_NOW=270000
     9  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=1200000
    10  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=1200000
    11  POWER_SUPPLY_HEALTH=Good
    12  POWER_SUPPLY_VOLTAGE_OCV=4194300
    13  POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000
    14  POWER_SUPPLY_VOLTAGE_MIN_DESIGN=3000000
    15  POWER_SUPPLY_CAPACITY=99
The image below shows the PinePhone (+ PP Keyboard) almost fully charged.
RE: Battery problem with a Pinephone keyboard and Mobian - by presire - 10-28-2022, 02:24 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 2,872 Yesterday, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 136 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,170 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 178 03-18-2024, 08:54 PM
Last Post: penguins_rule
  icon keyboard chris_02 3 515 02-09-2024, 08:53 AM
Last Post: 3x5co
  Keyboard not popping up on QT apps 3x5co 1 303 02-08-2024, 11:45 PM
  unofficial kali linux for pinephone help needed pinesmell 5 3,774 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,147 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Keyboard keeps disappearing the moment it's touched jojuma 1 578 10-29-2023, 08:34 AM
Last Post: walter1950
  New keyboard issue sandspur 29 12,943 10-05-2023, 02:27 AM
