atinout binaries for mobian/debian?
Does anyone have any binaries atinout for mobian on pinephone 1.2?
https://atinout.sourceforge.net/ does not have precompiled binaries for debian/mobian and attempting to compile from source results in a segmentation fault error.
(05-12-2024, 10:03 AM)NeutralGrey Wrote: Does anyone have any binaries atinout for mobian on pinephone 1.2?
Download the tar.gz file, and compile on a terminal:
$ gcc atinout.c -o atinout
or
$ gcc -O2 atinout.c -o atinout
If you get an error on line 173, modify this line in this way:
printf("atinout version \" VERSION \"\n");
I compiled it on mobian-bookworm without error, but i did not verify if it works.
I can confirm it works, sending these two commands with success:
echo 'AT+QGMR' | sudo ./atinout - /dev/ttyUSB2 -
echo 'AT+QMBNCFG="list"' | sudo ./atinout - /dev/ttyUSB2 -
  Mobian-Kicksecure? 3460p 0 172 05-26-2024, 02:09 PM
Last Post: 3460p
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 3,371 05-17-2024, 07:58 AM
Last Post: treebeard
  Mobian repository status henrythemouse 16 9,394 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 277 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,375 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,968 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 733 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 3,056 08-31-2023, 12:38 PM
Last Post: vusra
  how to update mobian over tor vusra 13 7,375 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 2,012 07-09-2023, 01:37 AM
Last Post: vusra
