Activating a SIM on Pinephone
Has anyone been able to activate a Tracfone or US Mobile SIM on the Pinephone and be able to make calls?  I have activated cards from both on my Pinephone and it seemed to go well but I can not make usable connections (calls usually do not connect at all) and the phone will not stay registered.
Do I have to get another SIM and activate it on a different phone?  That seems to be what most do.
I can't use any SIM in my Pinephone, I came here to also look for help.
It just doesn't detect the SIM card, it's as if it was not there.
I've tried with 3 SIM cards, all activated.
(04-17-2022, 05:23 PM)dxvargas Wrote: I can't use any SIM in my Pinephone, I came here to also look for help.
That sounds like defective hardware.
(04-17-2022, 02:24 PM)jhasler Wrote: Has anyone been able to activate a Tracfone or US Mobile SIM on the Pinephone and be able to make calls?  I have activated cards from both on my Pinephone and it seemed to go well but I can not make usable connections (calls usually do not connect at all) and the phone will not stay registered.
I got a SIM from Ting.  Checked compatibility: good.  Activated: successful.  Result: same behavior as with Tracfone and US Mobile.  Data somtimes works.  Calls sometimes complete but sound is always delayed and interrupted and the calls always terminate after varying lengths of time (usually just a few seconds but someimes several minutes).
Has anyone else successfully activated a Tracfone, US Mobile, or Ting SIM in the Pinephone and then had telephony work?
Typical ModemManager log entries:
<info>  [modem0] state changed (registered -> searching)
<warn>  [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
<warn>  [modem0] couldn't load operator name: Current operator id is still unknown
<info>  [modem0] 3GPP registration state changed (searching -> idle)
<info>  [modem0] state changed (searching -> enabled)
<info>  [modem0] 3GPP registration state changed (idle -> unknown)
<info>  [modem0] 3GPP registration state changed (unknown -> idle)
<info>  [modem0] 3GPP registration state changed (idle -> registering)
<info>  [modem0] 3GPP registration state changed (registering -> home)
<info>  [modem0] state changed (enabled -> registered)
I successfully used a Tracfone sim (ATT network) with a PP. Started using it a couple of years ago. Just moved it from my prior phone to the PP. Was problematic until upgraded to Biktorgi's firmware. After that it worked flawlessly, until today. Have a cell network registration issue that I have just started investigating.
(06-18-2022, 10:54 AM)joe_w Wrote: I successfully used a Tracfone sim (ATT network) with a PP.  Started using it a couple of years ago.  Just moved it from my prior phone to the PP.  Was problematic until upgraded to Biktorgi's firmware.  After that it worked flawlessly, until today.  Have a cell network registration issue that I have just started investigating.
Issue turned out to be tracfone's att mvno.  bought their bring your own phone sim kit ($1.00) and installed a t-mobile mvno sim card.  pinephone is now working normally.
  Pinephone visibly losing power while plugged in Hiraghm 10 9,649 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 1,969 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,266 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,669 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,946 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,764 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,363 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,043 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,399 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,821 10-21-2025, 12:12 PM
Last Post: Richy_T
