Pinephone stuck on 'something went wrong' after update
Hi, I updated my Pinephone using these instructions https://wiki.pine64.org/wiki/PinePhone_U...structions
$ sudo pacman -Syu
after his command it tried to do an update abut after a few minutes of downloading different packages it crashed and now when I start up the phone there's a screen that says 'something went wrong' with only a logout button. If I press logout, the Manjaro UI shows for a split second before the phone loops back to the lock screen again. Any thoughts on how to fix this issue and get it back to a working state? Thanks
(03-06-2022, 01:21 PM)gofishus Wrote: Hi, I updated my Pinephone using these instructions https://wiki.pine64.org/wiki/PinePhone_U...structions
$ sudo pacman -Syu
Easiest would be if you just reflash, https://wiki.pine64.org/wiki/PinePhone_I...structions
  systemic issue pinephone penguins_rule 3 425 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 243 03-19-2024, 10:36 AM
Last Post: penguins_rule
  Using too much juice since last update Eugo 20 3,723 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 1,915 02-13-2024, 01:19 AM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,616 10-02-2023, 05:07 AM
Last Post: Uturn
  new PinePhone upgrade issue WhiteHexagon 5 1,811 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Latest update Eugo 21 8,383 03-09-2023, 05:27 AM
Last Post: Eugo
  Can't add micro SD card to Pinephone thorensjubilee 7 2,536 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,496 02-04-2023, 08:35 PM
Last Post: Westslope
  Firefox issue with latest update Barugon 6 2,420 01-28-2023, 01:29 AM
Last Post: alaraajavamma
