USB-C Video Out Issue
Question
I've repeatedly encountered an issue where my PBP's video out only works once per login session. Throughout my workday I need to project my PBP using a Crestron system with an HDMI to USB-C converter. It works fine the first time, but when I remove the adapter and later attempt to project again, it won't work until I restart it.
Has anyone encountered this and/or knows where to look to try and debug it? A display service perhaps?
it may be helpful if you provide what OS you are using when this issue occurs.
I use the default Manjaro OS. Fortuitously, after upgrading yesterday to version 5.16.2-4-MANJARO-ARM it appears the problem was fixed, despite it having persisted across multiple updates in the past! Perhaps I should make these forum posts more often Smile
  Video Flashing/adjusting on boot and reboot jbradley419 0 307 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,700 12-17-2023, 09:29 PM
Last Post: insideau786
  U-Boot, video console, and visual artifacts dsimic 21 19,026 03-16-2023, 07:30 AM
Last Post: Tazdevl
  Newbie with immediate issue jasonumd 1 1,006 03-04-2023, 05:59 PM
Last Post: hacknix
  Kdenlive or other video editing software?? SuttonWillow 4 4,642 05-26-2022, 09:11 PM
Last Post: IsraelRobinson
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 997 04-16-2022, 07:41 PM
Last Post: gehn5
  Video : Review of the PineBook Pro with Armbian NicoD-SBC 1 2,700 07-06-2021, 10:10 PM
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 18,477 03-12-2021, 10:46 AM
Last Post: spikerguy
  Kdenlive or other video editing software? ImmyChan 2 2,927 01-19-2021, 01:12 AM
Bug [Fixed] Issue with mesa-git (Manjaro ARM Stable Update 2020-09-22)) JasonG-FR 20 22,003 12-12-2020, 05:09 AM
Last Post: mogwai
