Kdenlive or other video editing software?
I'm tempted to get a PineBook Pro once the new batch goes up for sale and I'm curious, can the PineBook Pro do some light video editing? I'll be coming over from a ThinkPad X220 and on that machine I'd sometimes do some light editing, stuff like putting a few video clips together and maybe adding some light effects all while using proxy clips in Kdenlive. Is the Pinebook Pro capable of doing that? If not it's not a deal breaker I'm just curious
(01-18-2021, 04:24 PM)ImmyChan Wrote: I'm tempted to get a PineBook Pro once the new batch goes up for sale and I'm curious, can the PineBook Pro do some light video editing? I'll be coming over from a ThinkPad X220 and on that machine I'd sometimes do some light editing, stuff like putting a few video clips together and maybe adding some light effects all while using proxy clips in Kdenlive. Is the Pinebook Pro capable of doing that? If not it's not a deal breaker I'm just curious
I don't like your chances, but there is hardware encoding/decoding, does kdenlive support hardware decoding/encoding?
Yes. So does Shotcut. I don't expect either to use this to an advantage on a PBP. But I could be wrong.
The short answer is, yes, the PBP is capable, if the software has a port that will run.
The long answer is that I think you'll be disappointed at the rendering time, even if you can get the software to run.
  Video Flashing/adjusting on boot and reboot jbradley419 0 286 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,591 12-17-2023, 09:29 PM
Last Post: insideau786
  U-Boot, video console, and visual artifacts dsimic 21 18,830 03-16-2023, 07:30 AM
Last Post: Tazdevl
  Suggested software for use case ehcorn 4 2,041 08-17-2022, 04:06 PM
Last Post: TRS-80
  Kdenlive or other video editing software?? SuttonWillow 4 4,599 05-26-2022, 09:11 PM
Last Post: IsraelRobinson
Question USB-C Video Out Issue dev 2 1,860 02-08-2022, 07:28 PM
Last Post: dev
  Video : Review of the PineBook Pro with Armbian NicoD-SBC 1 2,663 07-06-2021, 10:10 PM
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 18,339 03-12-2021, 10:46 AM
Last Post: spikerguy
  How Much Non-Free Software Does The PineBook Pro Use? ImmyChan 6 4,792 02-18-2021, 07:58 PM
Last Post: TRS-80
  Video Editing jiyong 3 5,006 08-28-2020, 06:39 AM
Last Post: PaulQ
