Newbie with immediate issue
Hi everyone. Newbie here and am having an immediate issue. First, my machine arrived with a malfunctioning screen. Replacement screen arrived and was installed easily. I booted and performed some application updates. Upon reboot my screen is black. I've seen this issue reported by others. I'm trying to reinstall Manjoo to the emmc. It boots just find from a microsd card and I want to use the installer. However, my network is disabled and no commands I issue will enable it. Has this happened to anyone who found a solution?
Thanks so much
Jason
(02-06-2023, 08:50 AM)jasonumd Wrote: Hi everyone. Newbie here and am having an immediate issue. First, my machine arrived with a malfunctioning screen. Replacement screen arrived and was installed easily. I booted and performed some application updates. Upon reboot my screen is black. I've seen this issue reported by others. I'm trying to reinstall Manjoo to the emmc. It boots just find from a microsd card and I want to use the installer. However, my network is disabled and no commands I issue will enable it. Has this happened to anyone who found a solution?
Thanks so much
Jason
Hi Jason
Sounds like you are not using the right Manjaro image and it doesn't have the right drivers for the network. I have done this myself before. Ensure you get the pinebook pro image, not the generic ARM one from the Manjaro site.
Also, I had this black screen issue after an update because "kms" was missing from mkinitpio.conf ....
  Newbie Question!! oniichann 3 889 10-26-2023, 07:09 AM
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 985 04-16-2022, 07:41 PM
Last Post: gehn5
Question USB-C Video Out Issue dev 2 1,873 02-08-2022, 07:28 PM
Last Post: dev
Bug [Fixed] Issue with mesa-git (Manjaro ARM Stable Update 2020-09-22)) JasonG-FR 20 21,892 12-12-2020, 05:09 AM
Last Post: mogwai
  Pinebook Pro PCIe init issue R32Fanboy 4 5,325 11-05-2020, 09:59 AM
Last Post: vssz
  Boot issue (red light) pineitup 10 10,132 11-01-2020, 11:26 PM
  Boot issue DarrowAtreides 0 1,717 10-29-2020, 07:23 AM
Last Post: DarrowAtreides
  Issue with screeen tilers - Anyone can recommend? motezart 0 1,624 10-20-2020, 10:35 AM
Last Post: motezart
  [AUG 2020] PBP Battery Issue (?) mercato 7 7,515 09-22-2020, 12:10 AM
  Graphics issue on ubuntu bionic das 0 1,689 08-03-2020, 09:39 AM
Last Post: das
